HELP! My camber changes when I change directions.
Old Jul 10, 2001 | 12:53 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
When my car moves forward,the top of the wheels go outward(neg camber,right?). But when I back-up,the top of the wheels go inward.I am getting excessive outer tire wear because of this.The problem just started about three weeks ago.And since then,my new 4 month old tires are completely worn on the outside edge,just in 3 weeks! That's how bad it is.I checked the upper strut mounts,and they are tight and not moving.I have a new idler arm.Checked wheel bearings for the hell of it-they seemed to be good.What else can I check for that would cause this? I am rebuilding my front end this weekend(new bushings,ball joints,struts,centerlink,tie rod ends,and pitman arm). I want to take care of this problem while I'm rebuilding my front-end.I'm hoping these new parts will take of this.If any of you might have an idea or solution to the problem,or suggestion for replacing other parts while I'm rebuilding this weekend,I would really appreciate it guys.Thanx.
'91 RS 5.0 TBI
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
Eibach sportline springs
ASCD SS hood, High-rise Z-28 spoiler,
Hooker super comp headers,dual 3" exhaust(Yes,I know.Overkill for this motor,but the whole set-up from headers to mufflers was FREE),two 1-chamber Flomasters,Iroc sway bars,wonderbar,140 Iroc gauge cluster,Iroc steering box,Auto meter gauges,dual guage A-piller pods,open air filter,AFPR,smog delete
TBI mods,180* thermostat,
383 stroker in the works
President-Austin 3rd Gen F-body c.c.
Austin 3rd Gen F-body c.c. message board at
www.hpsmotorsports.net
See my car and others at www.ride4life.net
[This message has been edited by RSpeed (edited July 09, 2001).]
Old Jul 10, 2001 | 08:16 AM
82camaro's Avatar
Car: 82 camaro SC
Something loose or broken in the front suspension. I would guess one of those parts you are replacing will correct it.
My guess: You may actually have a toe change from forward to reverse that looks like the camber is changing alot(the camber will change some when the toe is changed). A toe problem will kill the tires. Are you sure you got that idler arm tight?
Don't bother with the pitman arm, it's a 'no wear' item that has nothing to wear out on it. If the pitman is broke or bent(not very likely) get a used one.
Jack it up(suspension unloaded) and shake the wheels side to side(like you are turning left/right). Look underneath and see what is loose.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
morrow
Jan 13, 2024 12:29 PM
billybob6110
Feb 11, 2016 10:41 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
