umi camber plates
Old Sep 1, 2010 | 07:02 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
umi camber plates
hey people who have aftermarket strut mounts such as umi or j and m, did you use your stock strut covers or no.......
Old Sep 1, 2010 | 08:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: umi camber plates
no they dont fit any of them.
Old Sep 1, 2010 | 08:32 PM
88fastgta's Avatar
So I switched to those offroad boots and now my car is makin clunking noise now...when I turn and go over bumps......
Old Sep 1, 2010 | 09:04 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I have J+M and have no such noise... How is your alignment after the install?
Old Sep 1, 2010 | 09:26 PM
88fastgta's Avatar
I just got an alignment right after.. But I noticed that he didn't Really move the plates when I adjusted them.... It started makin the noise when I took the stock covers out and put those off road rubber boots on..... Maybe I should put them back on
Old Sep 1, 2010 | 09:31 PM
88fastgta's Avatar
Oh and my car is stock height if that matters.....
Old Sep 2, 2010 | 09:04 AM
so is mine (stock height).. i dont have any boot i just have the j+m plates with no dust cover.. its made like that. Looks like something else might be at play here... Mine was clunking when i had a loose k-member brace bolt, tightened it with lock tite and it went away.. i would check all steering components and braces and mounts to make sure everything is tight/greased.
Old Sep 2, 2010 | 09:14 AM
88fastgta's Avatar
i fixed the problem... loose bolts... thanks everyone...
Old Sep 2, 2010 | 01:28 PM
it's always something stupid on our cars lol..
Old Sep 2, 2010 | 06:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
for the record, in my first post, i though you were refeering to the plastic cap that goes on top of the stock strut mount, covering the nut on the strut's top. As far as the plastic cover for the shock itself, it can be made to fit. Couple people here have done it.
Old Sep 2, 2010 | 07:07 PM
88fastgta's Avatar
no i was actually talking about the plastic shaft cover that protects the shaft underneath the car.... i had to but the back on.. they do work but i cracked them a little bit but none the less they are on and no more klunky noise..... i just did a post about this but i have basically bald tires all around... would that affect my handling and cornering abilites... cause sometimes my car handles excellent then at other times its a little sluggish...... could the steering box or power steering pump cause this, because those are the only stock pieces i have left on my car thats associated with suspension, steering and handling...
Old Sep 2, 2010 | 07:18 PM
Bald tires would definitely affect handling! Tires make a world of a difference..
Old Sep 2, 2010 | 07:25 PM
88fastgta's Avatar
thats good to know because my rear tires have no tread left at all i mean none..... and the fronts have tread in the center but are bald at the outer edges..... i wonder how much of an improvement my handling would be with four new sumitumo htr tires...
Old Sep 3, 2010 | 09:14 AM
i had bald tires before in the rear, the fronts weren't too bad, so i kept em for spare. I put those new Firehawk Wideoval Indy 500 tires on and it handles incredibly better. Braking, traction, stability, predictability! It's all much better now. It's worth it.
Old Sep 3, 2010 | 11:43 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
if the rears have no tread, they are beyond shot. whould have been replaced years ago. fronts need more air pressure.
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
