Removing bump stops?
Old Jul 15, 2001 | 12:38 PM
MelloYello's Avatar
I have a 1990 Firebird Formula and I recently installed Jamex lowering springs. I think my front springs haven't settled yet because of limited suspension travel due to reduced clearance between my A-arms and the bumpstops. One A-arm is resting on the bumpstop while the other A-arm is about a half centimeter above the bumpstop. Would cutting an inch off my bumpstops help my springs to settle right, or should I remove the bumpstops altogether? Any advice is greatly appreciated.
Kyle
Old Jul 15, 2001 | 08:25 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
I wouldn't remove the bump stops,try cutting the pointed part off. how does the car handle with a 2" drop?
Old Jul 15, 2001 | 09:49 PM
nicmike85's Avatar
If you remove the bump stops then when the suspention bottoms out it puts the springs in coil bind. This will damage suspention parts.
Old Jul 16, 2001 | 03:48 PM
MelloYello's Avatar
Thanks for the info! I will try cutting about 1" off the top for additional clearance.
Junkyarddog - my car was only lowered about 1.5", but hopefully they'll settle to about a 2" drop in front after I trim the bump stops. Anyway, It handles great - freakin' awesome in fact! My car actually bottoms out less, has a smoother ride and corners smoother and harder than before! I would recommend lowering to anyone who owns an F-body. Thanks again!
Kyle
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
