Proportioning valve
Old Jul 16, 2001 | 03:25 PM
Z28DJP1987's Avatar
Proportioning valve
Where is the proportioning valve located on
a 1987 IROC with drum brakes, and do you keep the same location when converting to
rear disc's?
Old Jul 16, 2001 | 03:32 PM
ATOMonkey's Avatar
The valve is the odd shaped piece of metal under the Brake booster that has 6(?) lines coming out of it. It stays in exactly the same place. Are you replacing the Booster and master cylinder assemply too?
'89 Red Formula 350- 350 .060 over forged pistons 232* @ .020 cam Performer RPM Holley 750 DP Vortec 1.94 1.50 Hedman shorty headers Dual Exhaust w/ cutouts 1LE WS6 suspension, wheels, and brakes, 9 Bolt 3.27 Posi Edelbrock LCA's & Track bar subframe connectors 700R4 Harwood snorkel scoop Eclipse Head Unit Delco Bose Speakers 2 12" Pioneer subs w/ 400 watt/chanel amp
Old Jul 16, 2001 | 04:26 PM
Z28DJP1987's Avatar
ATO
Is the valve located below the master cylinder in the engine compartment? I don't
plan on replacing both unless I have to.
Old Jul 16, 2001 | 05:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Below the master cylinder with 2 lines from the M/C, 2 lines to the front brakes and 1 to the rear. There's also a single wire on it for the pressure differential warning switch.
Old Jul 16, 2001 | 08:42 PM
Z28DJP1987's Avatar
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
