Finally Solved Line Lock Problem!!!
Old Jul 30, 2001 | 04:27 PM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
For those who have a newer fbody such as a 1990 -1992 and have tried to put in a line lock with no success i have figured it out!! All you have to do is when you purchase a line lock such as hursts kit order 2 of the install kits for the 93-newer fbodys becuase the fittings that you need are in there and the only way to get enough is to purchase 2 kits since there is one in each one. The fitting I am talking about is the 11Mx1.5 to 3/8 inverted flare adaptor. Just put one on the dist block and one on the master cylinder and then attach the remaining 2 lines and wire it up and youre on your way!!!
Old Jul 30, 2001 | 07:52 PM
ede's Avatar
ede
i just went to auto zone and got what i needed and never bothered with the hurst install kits
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jul 30, 2001 | 11:56 PM
Omar's Avatar
I just went to the junkyard and got the fittings there. I did end up ordering the install kit just for the brake lines themselves.
I love my Hurst line lock. For a stealth install, I wired it to my momentary R/A switch on the cruise control.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
Polo Z03
Sep 10, 2015 06:43 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
