SQUEAKY BRAKES?!?!?
Old Jul 31, 2001 | 10:16 PM
CD MaroMan 91's Avatar
SQUEAKY BRAKES?!?!?
I have a '91 RS. Lately my brakes will squeak a little but when it's wet or after I wash my car they squeak HORRIBLY bad. I sound like a school bus. What should I do? Is there an easy fix at no cost. Or a cheap way out? Or should I plan to spend big money on this?
(orignally CDnAP48)
'91 Camaro RS (in readers rides)
Dark Metallic Blue
V6, 4th Gen Seats, Sony Xplod CD Player and Sony Xplod 6x9's, Kelly Charger Front Tires. Soon to come, DJSexay Kick Panels, Polk Audio Component Set, 2 Rockford Fosgate 12"
s, Rockford Fosgate Amp, New Rims, New Rear Tires, Carpet, Floor Mats, Paint Job, Interior Color Change.
E-mail me for any questions or comments.
AdidasPredator15@jam.rr.com
http://www.geocities.com/adidaspredator21/index.html
Old Jul 31, 2001 | 10:55 PM
RODS92Z's Avatar
Its probably your sensors on your pads or your pads are contaminated. Either way you need new pads.
1992 Camaro Z-28 5.7L auto t-tops arctic white
1967 Pontiac Catalina 2 door fastback 400 v-8 auto cameo white dark red interior
Old Jul 31, 2001 | 10:56 PM
My first car... I'm 16... I'm an idiot when it comes to cars... how much are pads and how hard are they to install???
(orignally CDnAP48)
Dark Metallic Blue
Old Jul 31, 2001 | 11:07 PM
RODS92Z's Avatar
You can get a set for under $30. Just remove the tire. Remove the two bolts on the caliper. Pull off the caliper ( may have to use some pursuading), dont damage it though. You will have to push the piston in to its bore first by using a bar. Put the bar into the hole on top of the caliper and pry the pads apart. Save the clip that will be on the pad thats against the piston ( you will need it on your new one). And just the reverse to install. to tighten the brakes up just pump the brakes. Oh yeah do not let the caliper hang by the hose, you may damage it. Thats another $20-25, plus you have to bleed that brake. Good luck.
Old Jul 31, 2001 | 11:15 PM
thanks a lot.... i'll just wait to get paid wednesday .... and that'll be my project before school starts on the 13th lol
(orignally CDnAP48)
Dark Metallic Blue
Old Jul 31, 2001 | 11:24 PM
RODS92Z's Avatar
P.S. I remove the sensors from the pads, so when they get worn down they don't squeak. I work on my car so I keep an eye on things like that. So its not a feature I care to have. You will need allen wrenches for the caliper bolts, cant remember the size.
Old Jul 31, 2001 | 11:26 PM
thanks a lot.... now i won't sound like a freakin school bus when i'm goin 2 school in almost 2 weeks lol
(orignally CDnAP48)
Dark Metallic Blue
Old Aug 1, 2001 | 05:47 AM
LarsZ28's Avatar
My brakes squeak when they get brake dust build up on them. Once I have cleaned them they are quiet for a while, until the brake dust build up gets to a certain point.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
