front sits way too high
Old Sep 19, 2010 | 02:32 AM
luke89's Avatar
Car: 96 jeep cherokee, 89 camaro
Engine: 355
Transmission: t5
Axle/Gears: eaton locker/3:73 gears
i got an 89 camaro rs and the front sits quite a bit higher than the back. its got new struts on it from the guy before me but idk if that would cause it to do that. ill try to post pictures tomorrow. should i just cut my front coils down a bit?
thanks
Old Sep 19, 2010 | 07:06 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: front sits way too high
struts dont affect the ride height. The front springa may have been removed and reinstalled wrong, or there was weight reduction in the front, or the rear springs have been messed with ect ect.
any pics by chance?
Old Sep 19, 2010 | 07:41 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
How many miles on car? Good chance that the rear springs, and shocks are whipped.....
Old Sep 19, 2010 | 12:56 PM
luke89's Avatar
Engine: 355
Transmission: t5
its got new shocks in the back. 119000 on the car. the guy before me had a big block in it.
kinda hard to tell in the pics but here they are
Attached Thumbnails front sits way too high-stuff-018.jpg   front sits way too high-stuff-016.jpg   front sits way too high-stuff-017.jpg
Old Sep 19, 2010 | 01:32 PM
J91's Avatar
J91
If he had a big block in it, he probably changed to heavier springs on the front, if it were me, I would replace them w/stock springs...
Is the 350 in the car now?
Old Sep 19, 2010 | 02:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
that probably right, if the old owner did have a big block, they its very possible he swapped in heavier springs to offset the additional weight. now that you have a small block, you have significantly less front weight than before, hence the higher front end
Old Sep 19, 2010 | 03:27 PM
luke89's Avatar
Engine: 355
Transmission: t5
yeah the 350 is in there now. thats what i was thinkin he did was put heavier springs in it. i dont have alot of money so would i be able to just cut them down?
Old Sep 19, 2010 | 05:50 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
to me the car sits high all around... you have alot of fender gap..... id replace the springs with eibach pro kit springs.... make sure they are indexed correctly..
Old Sep 19, 2010 | 06:15 PM
J91's Avatar
J91
Now that i lokk at it, it does sit high, allthe way around, he may have put heavier springs all the way around??? I'd change them all.
Old Sep 20, 2010 | 12:28 AM
luke89's Avatar
Engine: 355
Transmission: t5
the guy before me did have some 18's on it so he might of changed all the springs
Old Sep 21, 2010 | 05:33 PM
luke89's Avatar
Engine: 355
Transmission: t5
will buying lowering springs improve my handling over just cutting my old ones down?
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Dialed_In
Aug 20, 2015 01:45 PM
