Non-thirdgen, when I hit the brakes firmly on my 77 vette, the car stalls...
Old Aug 6, 2001 | 05:09 PM
Nick89TA's Avatar
I just picked up a 77 vette about a week ago. It is a 350, with a drawthrough carb turbo system, and an automatic. I can't tell if there has been a cam swap, but at idle, my vac gauge reads 20. Sometimes though, it will go down to 13 after i slow down to a stop. When I get on the brakes even a little more firmly than usual, it seems like the engine just sputters and dies. Any suggestions for what the problem may be? Do I need a vac reservoir? (space is a little tight) Thanks
Old Aug 6, 2001 | 09:06 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
Try to run a more rich idle mix.
Old Aug 6, 2001 | 09:55 PM
MikeS's Avatar
Does it do it only when braking, or will hard cornering tend to drop idle way down too? The reason I ask is cause I had sort of a similar problem with my '84 Camaro. Seemed like adjusting the carb floats fixed most of it. Of course, this is a complete shot in the dark.
MikeS's Avatar
Old Aug 7, 2001 | 12:36 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Will it try to stall if you are just sitting in park and you apply the brakes hard??
If so, check your booster/checkvalve.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Aug 7, 2001 | 01:07 AM
Nick89TA's Avatar
After doing some more testing with the brakes, and looking at the vacuum readings, I believe it may actually be the float levels on the carb that are messing things up. Thanks for the suggestions everybody!!
Old Aug 7, 2001 | 01:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds to me like the booster is defective...
ICON Motorsports
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
1nastygta
Aug 8, 2015 07:38 PM
