What torque arm to run w/ Lakewood Liftbars?
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
I'm currently running the Lakewood Traction Action Lift bars & wanted to upgrade my torque arm. Which ones best?....Spohn, BMR, Random Technology's.....? Also, on another post I saw someone mention that this combination would cause suspension binding (liftbars working against the torque arm), is this true?..would I be better off running just control arms & a torque arm? I just got my rear done & want my car to hook!Thanks for the info!
'91 Z28 1LE; 355, Sportsman II heads, Edelbrock TPI w/ 58mm TB, Tremec TKO 5-speed, 3.73's & much, much more
Those traction action lifts bars are bad if you drive your car on the street. I've actaully hear people say that it lifts the tires off the ground in cornering. I've also heard major quality control complaints like they break easy. do a search for them in this forum. this topic has been discussed before.
With a good adjustable torque arm and good control arms you should have no problesm launching. If your car is lowered might want to have control arm lowering brackets welded on too.
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
If you use the traction bars, you do not use a torqu arm.
They basically perform the same job.
I have all of the spohn's suspension stuff and I am running 1.90's 60' and 13.3 @ 100 mph
13.3 @ 100.3MPH 95 degrees and 95% humidity w/ no tuning on motor
Sportsman II, Gear drive, Perf. Res. chip, SLP 1 3/4" headers, Edelbrock muffler, Trans-go stage 3, Vigilante 9.5", Functional Ram Air hood, SLP roller cam, 24lb ADS injectors, AFPR, 3.45 gears, Stealth intake, 58mm setup, Spohn suspension, and other goodies...
raven
Custom EFI Intake Setup
raven
Hotrodboba400
Dec 10, 2019 07:07 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Dialed_In
Aug 20, 2015 01:45 PM
