Axles for a 9-bolt
Old Aug 6, 2001 | 04:48 PM
AFRO IROC Z's Avatar
Axles for a 9-bolt
I have an 87 iroc with the 9 bolt, are the axles for a 10 bolt the same as for the 9? If they are where can i get them? If they are not the same where can i get axles for the 9 bolt? and finally can the axles be changed with out taking the ring and pinion apart, and is there some where i can find an out line of the procedure for doing so? Thanks for any help.
Old Aug 6, 2001 | 05:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Nothing internal is interchangable between a 9 bolt and a 10 bolt. The only thing these 2 diffs have in common are the external mounts.
9 bolt axles can be removed by simply unbolting the 4 bolts that hold it to the end of the housing. You then just pull the axle out similar to a ford 9"
To my knowledge there are no aftermarket replacement axles available for the 9 bolt.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Aug 7, 2001 | 07:23 AM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
I have one stock axle if you need it....
Already sold the other one....
Old Aug 8, 2001 | 04:11 AM
I was wondering because sooner or later i want to replace my axles, but i want to do both, i haven't broken one or anything, but thanks anyway
Old Aug 9, 2001 | 11:30 AM
inadaz's Avatar
FYI: Moser Engineering makes replacement axles for the Austrailian 9 bolt. I emailed them yesterday and they quoted $295/pair, shipped two days after you place the order. Good Luck!
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
6speedIROC
Sep 13, 2015 01:29 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
