So many threads about rack and pinion setups and still not a motherloving answer!?
Old Sep 26, 2010 | 09:01 PM
ls1fiend's Avatar
Car: 1985 z28, 1994 Sierra
Engine: 350, 350
Transmission: T-5, 4L60E
I just want to know:
1, what will it take to make Spohn's setup work on a stock K member?
2, Someone on here wrote about a thunderbird R&P setup had close to the amount of travel needed but he had no clue how to mount it to the K member. Is this a manual R&P setup (which I want) and what modifications would I have to go through tie rod wise to make this the right length for a third gen setup. Am I going to have to drill out my spindles?
Old Sep 26, 2010 | 10:51 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Re: So many threads about rack and pinion setups and still not a motherloving answer!
The best way is to use the Racecraft spindles made for rack and pinion with the shorten arms, I chose to use the pinto rack because of the power it takes to drive the power steering pump. You get get mounts and weld them onto the factory k-member if you want to go that way.
The rack I use was shorten to fit the 3rd gen camaro's. Hope that helps
Old Sep 26, 2010 | 10:53 PM
ls1fiend's Avatar
Engine: 350, 350
Your rack isn't powered? I'm wanting a manual unit. The steering resistance is not a problem.
Old Sep 26, 2010 | 11:13 PM
572_Rat's Avatar
My rack is manual, it is made by Unisteer
Terrell351
Jun 13, 2021 01:13 PM
lt1z350
Sep 29, 2015 01:50 PM
89fast5oh
Aug 24, 2015 08:14 AM
overdriv
Aug 20, 2015 03:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
