installing rear control arms
Old Aug 13, 2001 | 10:49 PM
LeftTurn1LE's Avatar
I just got some tubular rear control arms and I have a couple of simple questions. First, can these be installed without upgrading anything else? Second, do these need to be installed in the air, then torqued on the ground? Any other helpful hints for someone whose never done this before? Thanks.
91 Z28 1LE 5.7 automatic
SLP 1 3/4 headers, Random Technology cats, Borla exhaust, Accel 8.8 wires, Hotchkis STB, Pirelli P7000 Super Sports P 245/50ZR 16
More to come...
Old Aug 13, 2001 | 11:12 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
1) Yes
2) Yes, torque on the ground at ride height.
It's fairly easy, just unbolt and swap. Don't forget the lube for the bushings and if they're greasable, ensure the fittings are pointing down so you can reach 'em.
Old Aug 14, 2001 | 06:32 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Only unbolt and change one lca at a time. It will make putting it back together alot easier.
Old Aug 14, 2001 | 09:07 PM
Thanks. Its a good thing I asked. The instructions don't say anything about torquing on the ground. They are greasable, which brings another question to mind. How much grease should I use? Also what should I torque to? Is it same as factory torque specs? I appreciate the help.
Old Aug 14, 2001 | 10:42 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
The LCA's I just got from SPOHN came with good instructions and they say to install hand tight then lower the car to the ground and tighten bolts to 72 ft/lbs. dry or 55 ft/lbs. lubed, I assume yours would have the same torque but I'm not sure.
92 Camaro RS 5.0 5-Speed (Quasar Blue)
T-Tops
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
Old Aug 15, 2001 | 01:51 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You can make the "torque down" part of life easier with a floor jack. Put the floor jack under the center of the axle, and raise the back of the car. Remove the rear tires. Now, lower the jack so the back of the car is at ride height. This will let you get to those lower control arm bolts easier, without fighting around the tire. You're still loading the rear suspension, since the weight of the car will be on the axle thru the floor jack.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Aug 16, 2001 | 11:14 AM
How much grease? About 5 pumps from a grease-gun? Thanks.
Old Aug 22, 2001 | 04:03 PM
TTT
What kind of grease and how much? Granatelli hasn't responded and no one at camaroz28.com has either. I need to know please. Thanks.
Old Aug 22, 2001 | 04:19 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Marine grease and enough till where it comes out the sides
Kat
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
