Brake problem (92 Formula)
Old Aug 23, 2001 | 06:29 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
I seem to be having a problem.
I just finished installing new rotors and pads on the front, and pads on the back (the rotors were turned as well...).
Heres the problem:
When I press the brakes after turning, or during a turn, it seems as though something catches the brake pedal/pads and the car pulls to one side (it sometimes changes sides) but then it seems to let go and stop normally once I push the pedal past that point.
You guys ever had that happen? I dont want to be killed by bad brakes!
Thanks,
Daniel
http://kiztope.50megs.com
92 Pontiac Firebird Formula 5.7/A4
K&N, nothing else yet!
92 Rs 3.1/T-5
Beautiful car, several mods, but now I am turning attention to the 'bird!
AIM : Theonekiztope
ICQ: 8787542
"Maybe one day life will take a turn. When it does Lean into it!" Leon Calrinsky (98)
Old Aug 23, 2001 | 11:46 PM
Andy89RS's Avatar
Wierd... Check the condition of the brake hoses. If they are really old maybe they kink when the wheel is turned and it takes some extra pressure for that hose to unkink?
Old Aug 25, 2001 | 10:48 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Thanks,
Hoses are good... fairly flexible...
Old Aug 26, 2001 | 08:28 AM
smurfmobile's Avatar
did you flush the system ? no air in there ?
sounds like you didn't
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
