solid motor mounts????
Old Aug 26, 2001 | 01:27 PM
87tpi420's Avatar
why cant we use them? does anyone know?
they are offered for other cars but specifically not ours. and what exactly is the function of the torque arm? do i really need it? mythoughts were if you used solid mounts the torque arm wouldnt function (how ever its supposed to) but it you canned the torque arm you could use solid mounts. which i would like to run all solid mounts
anyone done it?
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Aug 26, 2001 | 02:08 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I think you have a few facts mixed up. Motor mounts have nothing to do with the torque arm.
I have solid motor mounts in my car and they are specific for third gens.
Moroso part numbers
Upper mount #62510
Lower mount #62610
The solid mounts just keep the engine from torquing over under hard accelleration. If the engine doesn't move then the energy that used to try to rotate the energy is transmitted down the driveline to where you can use it. The downside to solid mounts in a street car is that there is no isolation between the engine and the frame. This means vibrations will be felt in the car.
Since the torque arm deals with the rear suspension and not the engine, replacing the motor mounts will have no effect on the torque arm. You still need the torque arm unless you change the rear suspension to ladder bars or a 4-link.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Aug 26, 2001 | 02:16 PM
87tpi420's Avatar
so... i have ladder bars welded in...i can scrap the torque arm? what about a solid motor mount?and lastly, you are bb not small...does that matter?
Old Aug 26, 2001 | 05:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
If you already have ladder bars then the torque arm isn't required.
Engine mounts are the same for BBC and SBC.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
