replacing sway bar links
Old Aug 27, 2001 | 04:24 PM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
On my 91 camaro RS, I have to replace my driver side back sway bar link. Does anyone know how hard this is to fix, and how do you cut the old one out, since its so close to the gas tank.
1991 teal camaro RS rebuilt 96 350 marine motor, comp cam, accel ignition,8mm accel plugs and wires, flowtech headers, stock exhaust, and rear end. (2.73)
Old Aug 27, 2001 | 07:23 PM
nicmike85's Avatar
This is not a hard job. Breaking the nuts loose might be. Go to your auto parts store and ask for polyurathene end link bushing kit. I would also suggest if you have a little time to kill to upgrade the bolt size to a 7/16 bolt. Take the new bolt and one bushing to a hardware store and you want to get the biggest bolt that will go through the bushing and the center sleeve. Once you have the size (i believe it is 7/16, Its been a while) just match the length with the original. now you have to drill out the washers to fit the bolt through. Now just put them on. Its not hard for our cars to break the flimsy bolt that comes with the sway bar end link kits. Thats why I suggest replacing it with a bigger one. make sure the bolt you get is grade 8.
Old Aug 27, 2001 | 09:05 PM
82camaro's Avatar
Car: 82 camaro SC
Measure the size and get yourself some solid endlinks(no bolt and spacer, just a solid rod with threads on each end with poly bushings).
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Aug 27, 2001 | 11:00 PM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
sounds simple enough thanks for the help guys =)
Old Aug 28, 2001 | 12:12 AM
Jza's Avatar
Jza
Hey, if you're gonna replace one with a poly, you should replace the opposite end as well. Otherwise, just get a rubber replacement. (Just depends on how cheap you want to be).
Old Aug 28, 2001 | 10:54 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The sleeve length should be 2 5/8" for the rears and fronts... $14 from Summit for the ES Polyurethane ones. Check out http://www.energysuspension.com for application info & part #'s...
-Tom P (Hot rodded 1986 Firebird 2.8l)
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
