WHY DOES IT SQUAT????
WHEN I GET OUT AND LOOK AT THE FRONT OF MY CAR ON LEVEL GROUND IT SEAMS TO LEAN OR SQUAT TO THE LEFT{"THE RIGHT SIDE IF YOUR IN THE CAR"} WHY DOES IT DO THIS? IS SOMTHING BROKE?? WORN?? WHAT SHOULD I LOOK TO REPLACE??? AND HOW MUCH WOULD IT COST?? THANKS
CHRIS
1983 firebird transam
CHRIS
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Unless the body is twisted, the car sits on the springs. Chances are the springs are worn out.
Car: 4
Engine: 6
Transmission: 5
If you still have the original springs, they are trash. You need new ones.
ICON Motorsports
ICON Motorsports
Check the posistion the front left spring was installed. Might have not been properly seated causing the left side to come up a little higher.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro.
SSC
Sep 24, 2001 09:56 PM
