eibach is gonna get a piece of my mind
Old Sep 1, 2001 | 01:27 PM
cobrakiller1989's Avatar
I just bought an eibach pro kit because i wanted to get a lower stance on my car. I didnt want to go too low because this is my daily driver. so i decided to go with the eibach pro kit. i figured the sportlines would be too low. well i measure the bottom of the ground effects, front and back, my front was 5 and 3/4" and my back was 6 and 1/4". After installing the pro kit(it is supposed to lower the car 1 to 1 and 1/2" all of the way around) my car now sits at 6 inches in the front(A 1/4" HIGHER!?!?!?!) and 6 inches in the rear. I am very diappointed with this kit. Has anyone had any similar experience with this kit? Or is there a chance that i did something wrong? I know the springs are installed correctly. Eibach says that their srpings are made NOT to compress more over time. If this is true i will be selling an eibach pro kit, brand new, for about 75% of what i paid. Let me know if anyone has a similar experience or knows something that could be wrong here.
thanks
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4 this summer)
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*NO recent time slips.
Old Sep 1, 2001 | 05:32 PM
kevinc's Avatar
Car: 1982 Z28
Are you sure you installed the front springs in the pockets right? There is a sloped seat that the spring end sits in, such that the end of the spring wire is between two drain holes in the lower control arm.
It's easy to miss, and will cause the car to sit higher. Go 'head, ask me how I know... :-)
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Sep 1, 2001 | 05:57 PM
Kevin. I am pretty sure that is what i missed. ill go to my shop on monday and check it out. I guess i wont have to harass eibach after all. thanks alot
Old Sep 1, 2001 | 06:43 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
It's not hard to get the front springs wrong. When I first swapped mine I had the same situation. I joked that it looked like a "Clown Car". After two attempts to get the tops of the springs to seat properly in the pockets I gave up and had Goodyear do it. I am very happy with the Eibach Pro-Kit springs.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Sep 2, 2001 | 07:34 AM
kevinc's Avatar
Car: 1982 Z28
Also make sure you have the flat end of the spring on top, with the rubber isolator pad taped to the spring so it stays in place during installation.
1982 Z-28
jbates346
Oct 21, 2015 01:50 PM
Zane Story
Oct 8, 2015 12:40 PM
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
Chiknhawk
Sep 10, 2015 08:55 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
