what subframe connecters should i use
Old Aug 19, 2001 | 11:42 PM
Hanks1's Avatar
im wondering if there are any mods you need to make to install weld on subframe connecters. Second where and what brands do you reccomend
84 Z28
78,000 miles
1970 350 ci 4 bolt chevy motor punched .030 over to a 355
stock 1970 heads with 1.94's and very mild porting
edelbrock rpm cam,intake, 750 4barrel
weisco 9.6/1 pistons & rings
edelbrock headers and catback (without the cat)
700r4 trans
3.23 rear (no posi yet)
Old Aug 20, 2001 | 07:52 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Spohn, enough said.
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Aug 20, 2001 | 06:05 PM
Bjase's Avatar
Car: 88 IROC
Everyone is so crazy over weld ins... I have Competition Engineering bolt in ones. They bolt in down their whole length and you could weld 'em if you want. They clear the stock exhaust system. Best of all, I've already swapped 'em from another car ( my Dad's 82 Trans Am ).
88 IROC with cobbled together (not by me)drivetrain, 86 (?) TPI unit,CE subframe connectors, Edelbrock strut tower brace, polygraphite bushings all around...it handles like a dream, but man is it hard to push!!
Old Aug 20, 2001 | 08:59 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Steve Spohn makes some very nice sub frame connecters that I would recommend to anybody. Check them out on his website.
Bjase,the problem with bolt in sub frame connecters is over time the stress on the bolts from torque elongate the holes in witch they are bolted through. When the holes get elongated the bolt in subframe connecters become useless.
[This message has been edited by Superman (edited August 20, 2001).]
Old Aug 21, 2001 | 08:42 AM
ATOMonkey's Avatar
I also think that the Spohn subframes are very good, but SSM also makes good connectors and have a good reputation.
Old Aug 21, 2001 | 06:09 PM
87RS402's Avatar
I'll be the oddball. Kenny Brown SFC's.
Old Aug 21, 2001 | 07:25 PM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
Me too Kenny Browns here also.
1989 rs ragtop LO3 KB subframes & edelbrock towerbrace to hold it together. edelbrock 3" cat back system.
Old Aug 21, 2001 | 08:37 PM
R.O.B.'s Avatar
Anyone know the websites to kenny browns, Comp Eng, etc... I'd like to see these to compare. Thanks.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
48psi regulator, (Nickel method)
Old Aug 21, 2001 | 10:30 PM
m3baller's Avatar
well,
the spohn's are made for drag racing, if you've ever seen his site and the kinds of cars he builds then you know what i mean..
i'd recommend weld in hotchkis.
hotchkis are great suspension parts for a daily driver/street warrior.
Old Aug 22, 2001 | 08:41 PM
Hanks1's Avatar
any mods for needed for edelbrock tes headers. My converter is installed its just punched
Thanks guys
84 Z28
78,000 miles
700r4 trans
Old Aug 22, 2001 | 10:57 PM
Rick89IROC's Avatar
I like the Jegs SFC on my convertible, they install right next to the factory body braces, really stiffen up the chassis, and don't have any clearance problems.
Rick89IROC
Black 89 IROC-Z Convertible 305 TPI
13.95 @ 102.18
DGGM 95 Impala SS
13.78 @ 98.28
[This message has been edited by Rick89IROC (edited August 23, 2001).]
Old Aug 22, 2001 | 11:23 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
<font face="Verdana, Arial" size="2">Originally posted by m3baller:
well,
</font>
Wanna see my car go do some auto x-ing?? I bet I should be able to kick some 02 WS6 but once I get the shocks in my car. Right now I got the Spohn SFC's and I gotta say outta all the ones that I've see they are the best. They are made outta the biggest box steel that ya can fit under the car. Yeah it makes the car a lil bit heavier but the pay off is well worth it.
Kat
Old Aug 23, 2001 | 10:27 AM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Spohn all the way...
Old Aug 23, 2001 | 11:40 AM
AntiVTEC's Avatar
I've got global west weld in units. Much much stiffer and i didnt lose one bit of ground clearance and all exhaust systems clear them.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro.
Old Aug 24, 2001 | 11:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Global West. Easy weld in, no exhaust modification to my 85 IROC.
JamesC
Old Aug 24, 2001 | 06:36 PM
DM91RS's Avatar
Car: 91 RS
I've had both weld ins and bolt on. They both work. Just remember that whatever type you use that it is always better to spread the connected load out as much as possible for the best results. IE: more welded or bolted on brackets or tubes. I have a mig welder so I use that type tied to a 6 point roll bar and still looking for ways to improve stiffness.
91 RS L31 350..... Vortec heads..... Holley 670..... Edel. intake .... Lt4 cam 1.6 rollers ..... Edel. TES headers .. 3" exhaust ..... 5spd 3.08
Old Aug 31, 2001 | 10:48 PM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
I've got Alstons. Cleared my dual cat exhaust with SLP headers.
'91 Formula
383CI Supercharged
5-speed
3.42
12.34@117.04, 1.91 60Ft.
on Drag Radials
Old Sep 2, 2001 | 02:02 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
i've heard a lot of good things about Spohn's i personally have SSM's..no problems at all..
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
InfernalVortex
Apr 20, 2021 11:31 AM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
