Sway Bar End Links
you tighten them untill the rubber bushing is compressed and expanded to the size of the metal washers
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Cool, thats what I did. Due to a lack of $, I put rubber back on, replacing the old blown out poly bushings. Is it normal for the poly type to fall apart after about 100K? I want to get a good replacement schedule going...
85T/A 305/QJ work in progress.
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
<font face="Verdana, Arial" size="2">Originally posted by SgtSkip:
</font>
</font>
Unlike rubber endlink bushings, poly doesn't need much preload to start the bar working right away. In fact, less preload is probably better with poly (with a little Locktite to ensure that the nut doesn't loosen up)
Actually, from a cost-no-object suspension function perspective, a split bushing design is not really appropriate regardless of the material, since the bottom of the link follows the control arm arc but the other end moves with the a-r bar in essentially a perpendicular plane. Rubber and poly are only low cost approximations of rod-ended links.
Pep Boys usually has a variety of poly endlink kits in stock for not that much $.
Norm
1979 Malibu w/some cornering tweaks and a few other interesting things
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
