rear calipers
Old Sep 4, 2001 | 08:04 PM
john72ss's Avatar
rear calipers
found leaks on my drivers side rear.... how bad are they to change?? the brake shop wants 300.00 and then they want me to rplace the rotor too...cause they cant resurface it past the point its at now!! said the caliper runs about 175 plus install...is i that hard to do myself??.....john 85 z28 with four wheel disc
[This message has been edited by john72ss (edited September 04, 2001).]
Old Sep 7, 2001 | 12:35 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Rear calipers are not cheap!! They are relatively easy to replace. You might have to drop the driveshaft so you can loosen the e-brake cable in order to get enough slack in the line. Other than that, just take everything off and make sure you don't drain the resovoir. Get new rotors and pads since you have everything apart. Its not rocket science, just take your time.
  • 89 Formula 305 WS6
    SFC's, LCA's, Air Foil
    Spohn Panhard Bar
    Flowmaster Cat Back, Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
    !cat
    CAI W/ K&N
    15.559 @ 88 MPH
    (Not good enough)
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
