What is wrong when the brakes are hard?
Old Sep 9, 2001 | 09:08 PM
90FormulaL98's Avatar
Car: 1990 Formula 350
Engine: L98 350
I have tried to lock the brakes up but cannot, The pedal gets really hard to push towards the bottom. It stops OK but not that quickly. I just replaced the pads and calipers on the front and had the rotors turned. I am at a loss.
Thanks, Gary
1990 Formula 350
13.8 @ 98 MPH 1/4
Old Sep 9, 2001 | 09:52 PM
98_1LE's Avatar
More than likely you have caliper(s) that are froze in the bore, or sticking at least. The rear disks (J65 option) are notorious for problems, and there are GM technical bulletins about it. AutoZone sells rebuild calipers very reasonably, so if rebuilding you own sounds like too much work, you may check into that.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Sep 9, 2001 | 10:13 PM
Engine: L98 350
I have not replace the rear brakes yet. So you think my problem is with the rear calipers?
Old Sep 10, 2001 | 08:19 PM
Eightyninef's Avatar
you don't have a problem, really. they are all like that. I can't lock mine either. your rear brakes are fine if they are 89+.
I have brand new bendix pads too. the car stops, but it will never lock them at hiway speed.
89 Formula
96 Impala SS
Old Sep 10, 2001 | 10:03 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
My brakes lock up way too easily. I can sure stop quick when I have to though.
Azrael91966669
25
Jun 20, 2017 04:04 AM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
