over weight
Old Sep 10, 2001 | 09:01 PM
silver89Rs's Avatar
over weight
i just put a new sound system in my car and the guy i baught it off of said that it wore out the springs of his car when he used it. do you guys think i should worry about this?
it weighs about 90lbs. and is in the backseat
Old Sep 10, 2001 | 09:11 PM
Jza's Avatar
Jza
nah. Even if that were true, you could replace the rear springs in a matter of 30 minutes...
Old Sep 10, 2001 | 10:22 PM
82camaro's Avatar
Car: 82 camaro SC
Springs don't really wear, they age. The extra weight may lower the rear end, but it doesn't hurt the springs.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 10, 2001 | 10:43 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Fat chicks in the back seat are heavier than that. Just go buy a new set of springs. They're probably just old and have lost their spring rate.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
PurelyPMD
May 5, 2016 04:57 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
Damon
Sep 26, 2015 04:29 PM
HikoriYami
Sep 21, 2015 07:11 PM
