New springs, front still higher!!!
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
i just put on eibach sportlines and the rear still sits close to an inch lower. When i installed the front springs, i made sure the tails were on the bottom and facing toward the engine. is there some kind of brace or spacer i should install under the rear springs to level the car out? i have a speaker box that weighs about 85 lbs with 2 12" subs in the trunk. could this be the reason? i also have fairly new shocks and struts on the car. any opinions or suggestions welcome.
86 305 TPI
700R4
3:42 axle
4 wheel disc
-Summit cam .442" lift
-Summit chain/roller
-Summit tranny cooler
-WORLD S/R Torquer 305 heads w/ LT1 springs
-High pressure oil pump
-Hypertech Airfoil
-SLP 1 5/8" headers
-CatCo cat.
-Flowmaster 80 series c/b
-Taylor Spiro-Pro 8mm
-Bosch Plat. plugs "hot"
-Indexed plugs
-K&N Air filters
-Trans-Go shift kit
-Removed AIR
-180 Thermostat
-T/B coolant Bypass
-All sensors replaced
-Custom Ram-Air
-Poly motor mounts
soon...
125 shot, slp runners, perf. chip, ported plenum
86 305 TPI
700R4
3:42 axle
4 wheel disc
-Hypertech Airfoil
-SLP 1 5/8" headers
-CatCo cat.
-Indexed plugs
-K&N Air filters
-Trans-Go shift kit
-Removed AIR
-180 Thermostat
-T/B coolant Bypass
-Custom Ram-Air
-Poly motor mounts
soon...
Car: 2002 SOM z28
I got new springs all around too and my front sits way too high. I am thinking I need to cut about 1/2 coil off
They say doing that will increase the stiffness (and these are stiff springs all ready), but if it lowers it 1", any increased stiffness would be overlooked! I imagine by removing the A/C and going with aluminum heads and glass hood I have also removed 100lbs+ from the nose...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
They say doing that will increase the stiffness (and these are stiff springs all ready), but if it lowers it 1", any increased stiffness would be overlooked! I imagine by removing the A/C and going with aluminum heads and glass hood I have also removed 100lbs+ from the nose...------------------
Car: 92 Z/28 Convertible
Engine: LB9
Transmission: Mad Dog Auto 700R4
Not sure if this helps, but Kenny Brown has spacers for the 4th Gen. A buddy of mine bought some 2 weekends ago in Indy, they were like $25.
I don't see why they wouldn't work on a 3rd gen.
Troy
92 Camaro Z28 Convertible
3" Flowmaster
Ported Plenum
Troy
3" Flowmaster
Ported Plenum
first of all get rid of the speaker box; 85lbs
no wonder it's lower that's a good start on solving your problem.
if it's still off a whole inch without the box which i doubt, someone has done something wrong with the install. did you replace the rubber bushings that cover the rear springs? the old ones worn or missing will cause a little variance.
as far as the front being a little higher; i've never seen an install where the front was actually lower or even to the back, usually the front is always a little higher; but not an inch higher (this will usually level out over time or when there is a driver in the car.
cutting the spring a half a coil won't make your ride stiffer; it will on the other hand make the front have a little floating effect. but, this will with out a doubt solve your problem. (as long as you took out the speaker box)
shocks and struts won't really affect your height either. it's only your springs; so if you are sure they are in correctly, i would remove the speaker box and re-measure, it shouldn't be that off; and if the little bit bothers you cut of a 1/4 of the top coil.... this will even it out and if you want a noticeable difference cut 1/2 off the top.
good luck
no wonder it's lower that's a good start on solving your problem.if it's still off a whole inch without the box which i doubt, someone has done something wrong with the install. did you replace the rubber bushings that cover the rear springs? the old ones worn or missing will cause a little variance.
good luck
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
the top is machined flat, not sure i could cut. when speaking with eibach, the tech. said something about loosening the a-arm while it's jacked up, tightening when it's down. think this would help?
ambainb
Apr 25, 2016 09:21 PM
TA8487
Aug 11, 2015 09:02 PM
