Manual steering box.
Old Sep 27, 2001 | 09:55 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
Did they make Thirdgen's with manual steering or do I have to hunt for something compatible.
If So what is compatible with a thirgen for a steering box.
Old Sep 27, 2001 | 11:07 PM
Tas's Avatar
Tas
no. Look for one from a 4 cyl S-10
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Sep 27, 2001 | 11:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The S-10/S-15 manual box is a direct bolt-in. You could also use the pitman arm but it's got a slightly different bend to it. It doesn't take much to reinstall the f-body pitman arm on the S-10 manual box.
You won't want to use a manual box if you're still running wide front tires.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Sep 28, 2001 | 06:56 AM
ede's Avatar
ede
hey PK long time no see. i put a manual box on my camaro, out of an 80 something s10. direct fit, had to change the pitman arm because there is a slight differance, but i bet you could use either if you wanted.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 28, 2001 | 07:14 AM
Car: 1986 Z28
Engine: 355
Transmission: th400
Thanks guys. Any particular year.. say like the 80's ones or does the interchangeability run into the 90's
Old Sep 28, 2001 | 09:47 AM
ede's Avatar
ede
mine came from a 80's truck but i bet about any will work. a thirdgen box fits a 1st gen f body.
Old Jan 7, 2009 | 03:33 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Re: Manual steering box.
sorry to bump this ancient thread, but i couldnt find any help, i have a s 10 man box that i bought, but the worm gear is smaller/shorter then the power box. anyone know where to get an extension/reducer?
Old Jan 7, 2009 | 03:51 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Axle/Gears: Moser M9/5:14 ratio/Billet Locker
Does your manual box have a 3 or 4 bolt top cover? You want the one with the 4 bolt cover. With the right box, this is a direct swap. Mine was out of a '90 s-10.
Old Jan 7, 2009 | 03:58 PM
crap, its a 3 bolt. guess i should of done some research before i bought this box, the guy had one in his car, said it was a direct bolt in but i could see he had an extsion on it.
Old Jan 7, 2009 | 06:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
And you had to find this old thread to dig up? There are many newer threads explaining the 3 bolt, 4 bolt top cover versions.
As stated above, you need the 4 bolt top cover box to be a direct swap. Some people have managed to convert the 3 bolt cover box to make it work but with the smaller sized shafts, it's a lot of work.
It was interesting to see my old sig. Back in 2001, I was only running 11.4's at 119 mph That was with my first BBC.
Old Jan 8, 2009 | 08:43 AM
yea, i was using the search. but hey at least u got a blast from the past. btw i like your car, i had been looking into your back halfing on your site.
Hotrodboba400
Dec 10, 2019 07:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Ian Irvine
Sep 4, 2015 08:08 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
