Upgrade suspension
Old Oct 22, 2010 | 06:27 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Upgrade suspension
So the suspension on my car is worn pretty bad.
It feels like it's walking up and down when turning in one extreme direction.
It pulls to the left when braking, I'm almost certain it's due to the worn suspension, anyone feel free to correct me if this isn't the case.
Very loose steering, 11-1 without wheel movement, though this probably is due to a worn steering box.
When braking hard the car lurches forward, and feels like the car is going to do a wheelie when accelerating fast.
I want to begin upgrading my suspension, what do you guys think needs to be changed?
Thanks for any advice guys.
Old Oct 22, 2010 | 07:02 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: Upgrade suspension
Man just replacing worn out parts helps a lot. A nice set of shocks does WONDERS. Even OEM style replacements. I'd get a prybar and start checking the whole steering system to see whats loose, like ball joints, idler/pitman arm, tie rods, etc. It definately needs an alignment, how are the tires? Pulling to the left sounds like a caliper hanging up or a brake hose broken internally... May need pads and rotors with a good brake flush and have the calipers lubed really well. Usually brings the brakes back to life....
Old Oct 22, 2010 | 08:46 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Alright, I'll look into shocks and springs first.
I replaced the pads and the rubber lines in the front and bled them and the problem persists. So I don't think it's the brakes.
The tires will be two years old this December, however they probably have less than 5000 miles on them. The car does not get driven very often.
Old Oct 22, 2010 | 09:02 PM
Mgb86's Avatar
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
I have to agree if it is pulling when you brake I would check the calipers. A great place to start would be here:
https://www.thirdgen.org/forums/susp...ion-101-a.html
and here:
https://www.thirdgen.org/forums/suspension-chassis/
For your steering problem try adjusting the box to take out the play. This tread was just started about the same topic.
https://www.thirdgen.org/forums/tech...rbox-slop.html
Old Oct 23, 2010 | 01:36 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
What Camaro305SB said first.
J-money
Jan 4, 2019 09:45 AM
Veaceonee
Sep 29, 2016 08:15 PM
starfinder
Oct 25, 2015 10:40 AM
84 TA NV
Sep 6, 2015 08:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
