What do I need suspension-wise to get low 12s, high 11s????
Old Sep 21, 2001 | 11:09 PM
CamaroX84's Avatar
I'm upgrading my motor to about 400 horsepower, and I've got a 2200 stall speed converter, a 700R4 tranny, and a 3.42 posi rear end. So, what should I do to get good 60' times and get a low 12 or high 11 ET? Will sub-frame connectors, adjustable torque arm, adjustable lower control arms, a lower control arm relocation kit, and 90/10 drag shocks do the trick? Any help would be GREATLY appreciated. Thanks.
Old Sep 22, 2001 | 08:56 AM
ede's Avatar
ede
you better lose a lot of weight or gain a lot of HP, 400 won't get you there. if you're serious i'd go with a 9" and box everything i could, run SFCs, air bags, LCAs, and if you stay with the 10 bolt run a girddle.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 27, 2001 | 09:11 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I run stock springs. 1.9 60 ft. lakewood lcas, and a jegster arm. 255 drag radials
You be the judge on what you need from what I have done and what mine runs.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Sep 27, 2001 | 10:01 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
Car's gotta go on a wieght loss program. Higher stall conveter, and more traction.
Gonna have to leave hard, and should get you to the low 12's with the stuff you have listed, but your gonna need some 3.73's more than likely and a converter aorund 3000.
To get into the 11's on 400hp you need it to launch real hard, and use all the ponies the whole track... ie taking advantage of gearing.. and having the car Light. Like 3200lbs or so... you could tickle the high 11's with cheaters on a 10 bolt
slicks will help but shatter the rear, if your launching hard enough to get legitimately into the 11's, no NOS
Edit : Just saw your from Il.
Don't know your elevation, if your altitude is up there your gonna need a lot more to get there on a timeslip... with no correction
I'm speakin from the ATco area.. 48feet above sea level
It's always SOMETHING
[This message has been edited by Pony Killer (edited September 27, 2001).]
Old Sep 27, 2001 | 11:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Some day I'd love to race at sea level just to see how fast the car can really run. Maybe I'll get to Mission BC next year. I want to see uncorrected 10's!
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Sep 29, 2001 | 08:46 AM
STUB25's Avatar
Stephen even i would like to see what you car could run at see level I went to your web page and I looks to me that at see level you be flirting with 9.99et's. You have a great setup and I think that you are right about your running at sea level.
db057
Apr 28, 2019 07:45 AM
Linson
Sep 21, 2015 01:08 PM
scottmoyer
Sep 7, 2015 07:06 PM
Stryker412
Sep 7, 2015 09:11 AM
MSgt Luttrell
Sep 5, 2015 11:28 AM
