91 camaro torque arm re-location bracket??
Old Nov 3, 2010 | 11:39 PM
91camaro248's Avatar
Car: 91 Camaro RS
Engine: 350 +60 Air gap Custom 750 DP
Transmission: 700r4 Stage 2 2400 stahl
Axle/Gears: Aussie 9 3.27 Posi
hello, ive been lookin at a umi torque arm relocation kit with safty loop. has anyone put 1 of these in??? how much did it help?? has anyone ever had problems with 400hp and the torque arm bolted to the trans???? any other places that make these??? has anyone ever welded the stock arm to the stock crossmember with a bushing????any info is appreciated.
thank you
adam
Old Nov 10, 2010 | 01:32 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Re: 91 camaro torque arm re-location bracket??
I am actually considering the same kit. I have way less then 400 hp with my car and am having problems with the stock torque arm mounting to the transmission extension housing. I have already damaged the the threads in the extension housing where the bolt that secures the torque arm is secured. I would hate to do any more damage to the tail housing of the transmission. I would be very interested to know what other people's experience is.
Old Nov 10, 2010 | 02:08 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
its not needed in my opinion... 4th gen ls1 cars have the same factory setup as ours and most midily buit cars are over 400 hp without that peice... really not needed for a daily driver.... i had one and hated it and sold it.... caused many vibrations..... here is my write up on the bmr piece... https://www.thirdgen.org/forums/susp...mber-alot.html
Terrell351
Jun 13, 2021 01:13 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
