TQ-ARM Shorter or Longer??
Has anybody worked on that?
We need the space on the left hand side next to the driveshaft(dual exhaust)!
Sitten under the car today we thought about doing a adjust. version that would mount on the level where the LCA is mounted!
The issue of TQ -ARM lengh was a topic on this board before, but we can´t find it!
www.camaro-firebird.de
you can run dual exhaust with the normal length torque arm...there are TONS of 4th gens over at www.ls1.com , do a search and you'll see a lot of pictures
also, there is a company that makes a shorter torque arm
www.bmrfabrication.com
89 Pro , no way you can compare the 4 and 3 gen floorpanels!
There is no space on the left side , check the pics on the website you stated!
We have seen duals, but sorry those cars are "hi riders" for us!
They all mount the pipes on a level lower than the trans mount!Good for stock ride hight! The first club canditade has a ride height of 78 cm taken from ground to mirror underside!
We do run Pg´s and manual trans on that project (far more space , than 700r4 cars!)!
Thanks for the BMR tip!
Pac J
May 17, 2020 10:44 AM
