Rear End Swap?
Old Oct 24, 2001 | 01:55 PM
RadarRunner's Avatar
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
Rear End Swap?
OK, I have been reading where 4th gen rear axles fit in the 3rd gen, But are they really just bolt in? I checked at a salvage yard a couple of days ago, & the guy at the counter said that it would not fit without a lot of work.
I am mainly considering the swap to switch over to disk brakes rear from drum, & think that from looking at 4th gen wheels (aftermarket or factory) vs 3rd wheels, I can get wider tires on the rear without sticking out too far. Plus they are 16" instead of 15"
Was I talking to the wrong person, because I was under the impression from the board that it was a simple (sort of) bolt in?
Thanks!
1987 Z28 Black & Silver 305 LG4/5-Speed . . .
NRA/AMA/FOP/IUPA/Blue Knights
Old Oct 24, 2001 | 04:32 PM
iroc5speed's Avatar
ok, time to clear up some misconceptions. the 4th gen rear will just bolt in. however, if switching to disks you need new e-brake lines and a new propertioning valve, and maybe (something else?). otherwise it bolts right up. It is 2" wider on each side, BUT, 4th gen rims have 2" more backspace then 3rd gen, so the widest tire you can get in there right now will be the widest you can get with the new rearend and new wheels. if you kep the 3rd gen rims, you can fit much wider tires on the back, but they will rub the quarterpanels if you don't have good shocks and springs.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
