Parking Brake Delete?
Old Oct 30, 2001 | 10:19 PM
Changa2's Avatar
I have a 3.23 Posi(Drum)in my garage and I'm doing a brake job on it before installing in my 87 Camaro.
When my buddy removed it from his 82Z he just cut the cables and jerked it out.
Here's my intentions but I'd like a more experienced opinion, before I go flying down the road.
Pull the remains of the cable from the backing plate and plug the hole and eliminate both the PB lever and PB strut, from the brake assembly.
Other than having no parking brake, do you see any potential problems?
Thanks.
Old Oct 30, 2001 | 11:43 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
None. The brakes will work fine without the extra hardware.
People with automatic transmission rarely use the park brake anyway. They just rely on the parking pawl inside the transmission to hold the vehicle.
Old Oct 31, 2001 | 06:36 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
They are normally required to pass inspection. Maybe use guys in Mich can get around that.
Old Oct 31, 2001 | 06:54 AM
MichaelRBrumm's Avatar
If anything in your brake system ever fails, you'll wish you had something extra to stop with (down shifting can only do so much).
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Sep 17, 2015 12:22 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
