Clunking noise when Accellerate Hard
Old Nov 3, 2001 | 07:34 PM
jcjohnston78's Avatar
At first, the noise was not that bad, it was a small clinging noise. Someone said it might be bad u joints or something like that.
After a road trip, it got worse. Now when i push down on the gas, its a real loud clunking sound and you can feel the back end shutters real fast. But if im already moving and i push on the gas again, no studder and no clunking.
Does anybody know whats wrong? How dangerous is this and is it expensive?
I have a 92 RS Camaro with 304TBI
Old Nov 3, 2001 | 08:09 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Sounds like you have a broken transmission mount.
You can get an Energy Suspension polyurathane one from some place like Jegs for around $23 or so and you won't have to worry about it breaking again, or you can get a cheap auto parts store rubber unit for about $10-$12.
Old Nov 4, 2001 | 04:57 AM
Already had the trans. mounts checked there still good....comming from back of the car
Old Nov 4, 2001 | 06:10 AM
El Guapo's Avatar
So have you had your U-joint inspected?
Old Nov 4, 2001 | 12:38 PM
IROCKZ4me's Avatar
Then pretty much all thats left is the driveshaft & U joints, torque arm & control arms, shocks, antisway bar, and rear axle internals.
Check the condition of each particularly all bushings and mounting points. Don't forget the front torque arm bushing, and the upper shock mount.
There may be damage inside the gear carrier/differential. A quick inspection there may be in order and while in there it would be a good chance to change the axle lube.
Old Nov 4, 2001 | 02:16 PM
so how dangerous is this if dont get it fixed right away, (someone told me that u joints & drive shaft might be dangerous) and if any of other parts, that could be bad....( i mean i drive real slow and not let the car make that noise?)
Old Nov 4, 2001 | 11:44 PM
IROCKZ4me's Avatar
You'll have to ask Miss Cleo about that. Without knowing what is actually wrong, who is to say how dangerous it is or isn't.
Best case scenario:
Find the problem then get it fixed if important, or determine that is is really not important or dangerous. No more problem
Worst case scenario:
Just keep driving. Something major in the rear suspension suddenly comes loose. There is no control! You crash into a stationwagon full of Nuns followed by a school bus full of kids and the resulting explosion kills everyone but you, but leaves you a quad for the rest of your life.
[This message has been edited by IROCKZ4me (edited November 04, 2001).]
Old Nov 5, 2001 | 01:48 AM
yea im getting it check tomorrow, most likely cant afford it but...at least ill know weither its ok to drive around and not kill a bunch a nuns and kids
92 camaro RS 305tbi
hypertech thermomaster chip and 160 stat
accel racing wires
accel supercoil
accel cap and router
splitfire plugs
db057
Jan 10, 2020 08:55 PM
luvofjah
Sep 26, 2015 08:28 PM
Breazlan
Sep 25, 2015 11:20 AM
Ragtop Man
Sep 12, 2015 12:23 AM
Randomtask2
Sep 7, 2015 05:06 PM
