Brake Calipers 82-92
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Except for the 1LEs, are the calipers from year to year and from front to rear interchangeable?
JamesC
JamesC
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Year to year front to front caliper swaps should work just fine, but not front to rear. Also, unless I'm out to lunch, you can't put pre-89 rear disc calipers on 89-up rears. The e-brake cables mount differently and I don't think the calipers will bolt into the carriers and onto the plates. I have both the 88 and 89 9-bolt posi disc rears but I haven't done the switch yet, so I haven't test fitted anything. (89 in, 88 out) Hope this helps.
Ed Miller
Charlotte, NC
1991 RS, 305 TBI,
bone stock driver;
1988 IROC L98
TPIS Fast Pack, modified MAF, MSD 6A, Dynomax cat-back so far.
"Do you want to race or don't ya? I want to race." Dale Earnhardt
Ed Miller
Charlotte, NC
1991 RS, 305 TBI,
bone stock driver;
1988 IROC L98
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Front Disc:
All non 1LE front calipers, 84-92 are identical.
Non-1LE front calipers 82-83 were a different thread for the brakelines (SAE instead of metric); this makes the rubber lines non-interchangeable. I don't know if the banjo bolt threadings in the calipers are different are not.
All 1LE calipers are identical.
Rear Discs:
All 89-92 calipers should be interchangeable.
All 84-88 calipers are interchangeable
82-83 calipers are interchangeable.
82-83 are not interchangeable with 84-88 due to the SAE vs. metric fittings problem.
'89-92 read discs will mount on an '82-'88 rear (and vice versa) assuming you swap the backing plates. 9 and 10 bolt backing plates are different. You'll also have to swap hard lines (or fabricate your own) and rubber caliper lines (not the center one).
You're only mildly out to lunch. The backing plates and ebrake cables are different, so are the rubber lines and the hard lines. Swap all that and you are good to go.
"Beware he who would deny you access to information, for in his heart, he dreams himself your master"
'84 Black Camaro Sport Coupe ZZ4 350 M6 -- '84 Olds Cutlass Supreme 231 A3
'91 Medium Blue Metallic Z28 400 A4 -- '99 Navy Blue Metallic Firehawk #120 346 M6
Rear Discs:
<font face="Verdana, Arial" size="2">Originally posted by ebmiller88:
Also, unless I'm out to lunch, you can't put pre-89 rear disc calipers on 89-up rears. The e-brake cables mount differently and I don't think the calipers will bolt into the carriers and onto the plates.</font>
rb85TA
26
Sep 14, 2015 10:29 PM
rudolphschenker
Sep 4, 2015 02:41 AM
