upgrading from 15" to16" wheels
Old Oct 26, 2001 | 06:38 PM
91FIREBIRDGT's Avatar
Car: 1991 Firebird
Engine: 3.1LV6
Ok, I'm going from the stock 91 15" wheels in the rear to the 16" Formula wheels of the same style. What tires should I use on the 16"s? Also I have drums in the rear, Do I need spacers? If so, what size spacers do I need? You're help is appreciated.
1991 Pontiac Firebird V6 W68
Pioneer DEH-7000R, Pioneer 6X9 4way/4X6 2way speakers, MTX 250watt amp, MTX 400watt sub, custom intake, Flowmaster dual exhaust 80 series, PIAA HID headlamp conversions, custom tail lamps(regular F-bird but amber is now red), many more to list...
Old Oct 26, 2001 | 07:46 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
The 16" aluminum wheels only came with spacers on cars with the iron drums. If you have the aluminum drums, you don't need spacers. If you have iron drums, I would suggest that you goto a junk yard and find some aluminum drums. They are 5 pounds a peice lighter.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/30/01)
There can be only one!!
Old Oct 26, 2001 | 09:22 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
the stock size is 245/50-16. you can put on 255/50-16
Old Oct 26, 2001 | 10:03 PM
82camaro's Avatar
Car: 82 camaro SC
So you want to have 15's on the front and 16's on the rear, right? The spacers aren't very thick, I would at least bolt the wheels on and see what you think. You could also put the 'front' offset 16 inch wheels on the rear--they stick out a little bit further. For the right look, the tire height on the rear need to be the same height or taller. I'm guessing 255's will do that.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 2, 2001 | 06:53 PM
Car: 1991 Firebird
Engine: 3.1LV6
BTTT
Pioneer DEH-7000R, Pioneer 6X9 4way/4X6 2way speakers, MTX 250watt amp, MTX 400watt sub, custom intake, Flowmaster dual exhaust 80 series, PIAA HID headlamp conversions, custom tail lamps(regular F-bird but amber is now red), soon to have 16" Formula wheels.
Future Mods: Ram Air hood(98-up style), 4th gen style rear wing, custom Pearl white paint, 3.4L V6 engine swap, custom headers, the list never ends....
my webpage: www.geocities.com/lilsap23/SEANs_HOME_PAGE.html
[This message has been edited by 91FIREBIRDGT (edited November 02, 2001).]
Old Nov 5, 2001 | 07:17 PM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
I would definetely mount the rims first and see. I had a 92 firebird V6 and I had my GTA 16's on it for about a week, I didn't have any problems with rubbing but the tire cleared the inside by about 0.50 cm.
Old Nov 5, 2001 | 08:35 PM
Z28DJP1987's Avatar
Use the .170 thick spacers with the iron drums and 16" Alum wheels. This was GM's
stock aplication.
Old Nov 8, 2001 | 02:14 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I have a set of spacers if you need them.. email me if you want them.
morrow
Jan 13, 2024 12:29 PM
angel2794
Sep 8, 2015 06:22 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
mrdevontay
Sep 2, 2015 08:04 PM
