Dieting a 3rd gen
Old Nov 22, 2010 | 12:11 AM
J$Money's Avatar
Car: 1980 Chevy Stepside
Engine: 5.7L 350
Transmission: TH350
Axle/Gears: 3.73 L-Slip
Dieting a 3rd gen
Where did you remove weight and how much total
Old Nov 22, 2010 | 06:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Dieting a 3rd gen
Hey, J$, as you can imagine there hasn't been much on TGO that hasn't been asked and answered. As a consequence, a search is usually a good idea. Check the thread to follow:
https://www.thirdgen.org/forums/body...on-thread.html
JamesC
Old Nov 22, 2010 | 02:24 PM
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
I ripped everything out of the interior and engine bay that was not absolutely neccessary. Carpet, headliner, back seats, spare, jack, ac, heat, smog pump, ac compressor, cats, exhaust stopped at doors, interior plastic, passenger seat, tubular K member, tubular a arms, tubular trans crossmember, tubualar torque arm. The door panels and electric windows are all still there. With a small block it weighed 2900 pounds with a full tank of gas and no driver. With a big block it weighs 3000.
Old Nov 23, 2010 | 12:17 AM
J$Money's Avatar
Engine: 5.7L 350
Transmission: TH350
Good god, do you have any pictures of it
Old Nov 23, 2010 | 01:26 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
removing weight is a joke i feel... but if you insist, the above link helps. i removed my passenger seat and rear seats. and run on a 1/4 tank of gas all the time..
Old Nov 23, 2010 | 07:45 AM
Zantasmo's Avatar
Car: '87 Iroc-Z, '91 Trans Am Vert
Engine: 5.7 LS1, 5.3 LS
Transmission: T56, T56
Axle/Gears: 4.11, 3.27
Lighter car accelerates, handles and stops better than heavier one.
It's a great joke!
Old Nov 23, 2010 | 08:04 AM
It's a great joke!
what i said came out wrong, i meant its no joke..thats why i took out my seats..
Old Nov 23, 2010 | 09:37 AM
Car: 1992 Camaro RS
Transmission: WC T5
Here's the only pic I have of the interior. I left the dash in but I took everything inside it out except the gauges. Also there is a tubular K member and A arms in the engine bay now.
Attached Thumbnails Dieting a 3rd gen-img_0123.jpg   Dieting a 3rd gen-img_0125.jpg
Old Nov 23, 2010 | 10:05 AM
KillerJoke07's Avatar
Car: 1991 Camaro Z28 & 1982 RS
Engine: 305ci Holley Carb & Intake
Transmission: 5 Speed T5 (Stock)
Axle/Gears: 10 bolt 2.73 Posi (Stock)
Would you remove the Front Bumper? Leaving the cover I mean, 'cause it weights a ton.
Will it be Ok on a dedicated Race Car?
Old Nov 23, 2010 | 11:07 AM
Car: 1992 Camaro RS
Transmission: WC T5
The front bumper is structural. It ties into the subframe. I wouldn't just pull the bumper. I imagine that would hurt the rigidity of the front end too much. I removed mine but had a local shop make a tubular one. I forgot about that peice. It was a LOT lighter. This also allowed me to open up the grill and put oil coolers on the tubular bumper, and remove the spoiler on the bottom of the radiator because the car has a real grill now.
Old Nov 23, 2010 | 02:24 PM
Thank you very much I didn't think about that.
The tubular one sounds right, thanks again
ex-x-fire
Jan 12, 2024 01:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
