disc break rear
Old Nov 19, 2001 | 07:54 PM
thesasquach's Avatar
disc break rear
i just puchased a 3.27:1 geared posi rear with disc brakes from a '88 GTA i am going to install it in a '91 RS with a TBI 305 and a 5 speed my question is this. is there any other items i need to change to make this brake swap? ie.. master cylinder brake porpotioing valve or brake lines ..... i hope this isnt a redundent question ....... and on a side note how do you remove the shifter **** from that 5 speed stick?
Old Nov 19, 2001 | 08:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It depends... can you live with the early style Moraine calipers that will be on the 88 rear, or do you want to upgrade them to the 1989 and later PBR calipers?
Old Nov 19, 2001 | 09:20 PM
im not sure if i can live with them or not whats the pros and cons?
Old Nov 20, 2001 | 12:05 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
89+ disc
Pros: bigger calipers, reliable ebrake
Cons: possible master cylinder/ proportioning valve swap
88- disc
Pros: ummm
Cons: smaller rotor, crappy ebrake
Do you have disc or drum now?
Old Nov 20, 2001 | 12:07 PM
Omega's Avatar
Engine: LS1 / LS3
To remove the shifter ****.. unscrew it.. righty tighty, lefty loosey. Check for a set screw but i don't think there is one.
Old Nov 20, 2001 | 01:08 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Whether or not you need a new front-to-rear brake line depends on where how your original prop valve matches the donor car's prop valve. I don't think you'll have a problem. (82-84 F-bodies had the front-to-rear line enter the "front" of the prop valve; on all the others I've seen, the front-to-rear line enters the bottom of the prop valve.)
A new prop valve from GM is about $70.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 20, 2001 | 03:54 PM
i currently have drum rear brakes. i beleave the '88 discs will be an improvment over the drums and will more than likely upgrade to the larger '89 up unit at a later date.
there is no set screw on the shifter **** and i have tried unscrewing it and am afraid of damaging the shifter the whole thing tries to rotate .... im not used to a top loader trans .... my experience is late '60s early '70s mopars
Old Nov 21, 2001 | 01:12 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
List to change for 90-92 drum to 89- disc rear:
E-brake cables
E-brake pull-up mechanism
hard brake line (attached to the differntial)
4th brake line (passenger side, goes from caliper to the hard line)
Your Brake Master cylinder (has a "A50" cast on the underside of it) and proportioning valve (made of extruded aluminum) should be OK. I also recommend that you swap out the wheel studs on the axle flanges to longer ones. Just drive them out with a hammer and drive new ones in with a 1/2" drive extension through the spot where the brake caliper sits. You don't have to pull off the axle. I got longer studs at Pep Boys. Good luck, Lon.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
novaderrik
Aug 10, 2015 12:44 PM
