Front wheels wobble in reverse!?
Old Dec 7, 2010 | 11:40 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Ok so ive finally gotten around to posting this, its happened for as long as i can remember and its gotten old finally, when i back up in my camaro and crank the wheel, the front wheels do this weird wobble-hop-gonna fall off type thing.
Kinda vauge i know, i di multiple searches with no luck....
just to cover the bases:
1. YES my wheels are torqued down
2. New(er) Poly bushings front to back on the car, problem existed even before replacement
3. Not doing anything crazy, just putting it in reverse and turning the wheel, happens more often when its wet
Normally i wouldnt care but i almost took out a customers car today with my front end, its un predictable on our tile floor and so i figure its time to get this bug fixed
TIA
Old Dec 8, 2010 | 12:03 AM
avilla20's Avatar
Car: 1990 rs/1986 iroc-z
Engine: Lho 3.1 v6/Lb9 5.0 v8
Re: Front wheels wobble in reverse!?
whats it like on the road, can you post a video? you check wheel bearings outter tie rod ends?
Old Dec 8, 2010 | 04:35 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Its fine on the road, but the wheels just hop, everything steering wise has been replaced as of last year, and the problem is still around though, forward with a full turn there's no problem but in reverse its like a shakey old man trying to hobble around
Old Dec 8, 2010 | 02:29 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Might be too much positive camber. when was the last time you had an alignment?
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
wruiz
Aug 11, 2015 02:59 PM
