4th gen rims
Old Nov 21, 2001 | 04:58 PM
89_G92_Iroc's Avatar
4th gen rims
If I had 2.5" spacers with 4th gen rims could I run 275/45/r17 with no rubbing?
Old Nov 21, 2001 | 05:39 PM
SoCo80p's Avatar
running a spacer that thick is VERY dangerous, the wheels would fall off!
Old Nov 21, 2001 | 05:55 PM
89rsvert's Avatar
Car: 1989 Camaro convertible
I have run 2.25 in the front of mine for two years and never had a problem. So, I don't think 2.5 will cause a problem. Don't know if 275's will fit. Sorry
89'Camaro Convertible,96'firebird wheels,79'Z28 hood scoop,soon to be a 350 tuned port injection engine, 3.27 posi disc brake rearend,36mm front sway bar, 24mm rear bar, all donated by a 89'Formula 350, Poly sway bar bushings and end links, Dark yellow green paint from Bonnevilles, tan www. mrmikes.com leather interior,Macewen white face gauges.
Dreaming of a RamJet 350,
Jet fan switch
180 degree thermostat
Flowmaster cat back system
2nd place is always the first loser!
Old Nov 21, 2001 | 06:14 PM
camaro6spd's Avatar
what size spacers are needed to fit the 10 spoke SS wheels....17x9.5 I think they are 275/40/17
Old Nov 22, 2001 | 04:25 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Yes, you can run 275/40/17's on your car with the bolt on spacers.
I have 2-1/4" all the way around which work fine for my 16x8 wheels, but when I put on the 17x9.5 wheels it sticks out in the rear a little bit. Normal spacer for the rear is a 1-3/4" spacer.
Here is a pic of mine with the 16x8's, notice the rear wheel lines up with the rear fender lip.
If I have a chance, I'll slap on the 17's on the rear and take a few pictures.
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Nov 22, 2001 | 02:59 PM
camaro6spd's Avatar
even with my car lowered 2"....I am worried about them rubbing the top of the well. So I should get 2.25 and 1.75. How much are these things.
Old Nov 23, 2001 | 03:33 AM
Zepher's Avatar
I got my set from VetteBrakes for $353 shipped to my door for (4) 2-1/4" spacers.
the 1-3/4" ones are $10 cheaper per pair.
Comes with 40 lug nuts, 20 to bolt spacer to hub and 20 to bolt wheel to spacer.
Make sure that you give them the hub thread size, otherwise they will send you the lugs to bolt to a Vette. Can't recall off-hand what the thread is.
WS6 Trans Am.
[This message has been edited by Zepher (edited November 23, 2001).]
Old Nov 23, 2001 | 07:59 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Thread should be the same on all of them and it should be M12 x 1.5 x 43.
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
