roll cage
Old Nov 24, 2001 | 03:05 AM
jester111's Avatar
roll cage
Good day people
Im inquiring on some info concerning a rollcage installation on a 1980 z28.
What is the best way to raise,level the car to ensure no bodytwist or slop.Thanks for any input.
Old Nov 24, 2001 | 06:32 AM
ede's Avatar
ede
park it on a known lever surface and use an angle finder to check several locations on the car, i use the inside of the door openings for fore and aft and the radiator support and rear deck lid for side to side. after you have the measurements jack the car up, support on jackstands and use plywood shims under the stands to replicate the measurements you had while the car was sitting on the known level surface.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Nov 24, 2001 | 04:43 PM
jester111's Avatar
Thanks ede!
I take it that the tire pressure's should also be the same. I should have metioned that my car in question is practicly stripped the frame is on the car everything else is off, im really concerned about bowing of the car fore and aft, where would be the best place to position the jackstand?
Thanks again
Old Nov 24, 2001 | 07:36 PM
nicmike85's Avatar
The suspension would be the ideal place to put the jack stands. The problem is that the car will flex while your moveing around welding in the cage. If you put the stands anywhere else under the car then it will flex in an unnatural position. It really needs to be put on a fixture for accuracy. This could be a jig (even if you made it) or a frame machine.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
FueledSoul
Sep 30, 2015 09:18 PM
FormulaEngland
Sep 30, 2015 01:50 PM
tmork454
Sep 29, 2015 06:33 PM
