Traction Bars
Old Nov 24, 2001 | 10:34 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Traction Bars
What are the best traction bars or traction enhancing parts that i can put on a 1971 Chevorlet El Camino with a coil spring setup? The car has 3.73 posi and spins very easily with 275/60-15 with an occasional wheel hop. Also bigger tires/slicks are not an option. Thank you.
Brady
"I see myself as a huge fiery comet, a shooting star. Everyone stops, points up and gasps "Oh look at that!" Then- whoosh, and I'm gone...and they'll never see anything like it ever again... and they won't be able to forget me- ever."~Jim Morrison
Old Nov 24, 2001 | 10:45 PM
nicmike85's Avatar
Surprisingly it would have to be polygraphite suspension bushings. These are realitively inexpensive and have alot to offer. Putting them in can be difficult but worth the hassle.
Old Nov 24, 2001 | 10:49 PM
I already have poly bushings.
What would be a good traction bar, I have seen some in Jegs for coil spring setups?
Thank You
[This message has been edited by brodyscamaro (edited November 24, 2001).]
Old Nov 25, 2001 | 01:48 PM
ttt
Old Nov 27, 2001 | 05:28 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
I don't have a leaf spring car but from the looks of what's around I'd say the bars made by Calvert racing, called Caltracs. You can check them out and read the info section about the idea and how it works at their website.
http://www.calvertracing.com/
[This message has been edited by ryn28 (edited November 27, 2001).]
Old Nov 27, 2001 | 07:30 PM
Dr. Pepper's Avatar
Those suspension systems are horrible when it comes to traction and wheel hop. The old LS-6 Chevelles were a real hoot with that suspension system. Around 500HP and enough traction to just beat a VW Bug. What I have heard of working well without a ton of work is relocating the upper control arms. This is done with a bolt on/weld on arm to move the mount on the rear end. I went digging to try to find some part numbers/prices. I think Hotchkis makes what I am thinking of but they are calling it a "trailing arm mounting brace" for $102. Summit part # HSS-1402. But I may be mistaken and it may be something else. Jegs definately has what I am thinking of by Lakewood. Its part number 620-21609 for $125. You can also check out the info on the Lakewood traction bars here http://www.mrgasket.com/lakecat.htm . There are other things you can do to help traction like boxing in all of the control arms or replacing them with aftermarket pieces. Still I would start with relocating the ICG to a better location with the traction bars.
Old Nov 27, 2001 | 07:34 PM
Mr. Pibb's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Dr. Pepper:
Those suspension systems are horrible when it comes to traction and wheel hop. The old LS-6 Chevelles were a real hoot with that suspension system. Around 500HP and enough traction to just beat a VW Bug. What I have heard of working well without a ton of work is relocating the upper control arms. This is done with a bolt on/weld on arm to move the mount on the rear end. I went digging to try to find some part numbers/prices. I think Hotchkis makes what I am thinking of but they are calling it a "trailing arm mounting brace" for $102. Summit part # HSS-1402. But I may be mistaken and it may be something else. Jegs definately has what I am thinking of by Lakewood. Its part number 620-21609 for $125. You can also check out the info on the Lakewood traction bars here http://www.mrgasket.com/lakecat.htm . There are other things you can do to help traction like boxing in all of the control arms or replacing them with aftermarket pieces. Still I would start with relocating the ICG to a better location with the traction bars.</font>
Heyyy long time no see. Where have you been?
Mr. Pibb
1991 RSS
I NEED MORE CUP HOLDERS!!!!!
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
