Pics of 6. or 8. rollbars with interiors
Old Nov 27, 2001 | 05:04 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
I'm looking to get an 8. rollbar so I can run a set of ET Streets out back. I'm undecided wether to get swing-outs, the kits that retain the factory arm rests, or to take the armrests out and use the straight bars for more room. The only thing I know for sure I want is the two bars going to the hatch that go over the rear seats keeping them semi-useful. Anyone have pics I can check out and/or advice on the best ay to go?
1986 T-Top Z-28, ZZ-4 Crate Engine, Complete High Flow TPIS TPI, SLP 1-3/4" Headers, 3" Exhaust, 3.73 gears, Moser Axles, Auburn Pro-Series Diff, 2800rpm 10" Non-Lockup Conv., 90/10 Front's, 40/60 Rears, Spohn LCA's, LCA's brackets, SSM SFC.
Old Nov 28, 2001 | 12:15 AM
cy Z28's Avatar
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
HUH? So you can run ET Streets? What does that have to do with anything.
www.wolferacecraft.com
Old Nov 28, 2001 | 07:50 AM
SteveSpohn's Avatar
http://www.spohn.net/oldsite/z28.htm
Spohn Performance: F-Body Chassis/Suspension Specialists
Old Nov 28, 2001 | 02:35 PM
ryn28's Avatar
Engine: Chevy ZZ4
What it has to do with is chassis strength. You can put a 700HP engine in your t-top car, or any car for that matter, and if you only run radials you have nothing to worry about. Once you start getting real traction it's another story.
lee01
Apr 9, 2016 01:56 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
neekolzun
Aug 24, 2015 04:59 PM
Linson
Aug 21, 2015 02:12 PM
