1992 Z28 Sway Bar Size
Old Dec 22, 2010 | 01:20 PM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
Anyone know the sway bar (mm) size for a 1992 Z28 Camaro (5.0 LB9).
Front and rear
Thanks!
Old Dec 22, 2010 | 01:31 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 1992 Z28 Sway Bar Size
Only way to know for sure is to measure it. Different packages had different bars, and of course GM is famous for throwing on what they had on hand at that minute. I've seen stock RS's with 32mm up front as well as 34mm, some Z28's got 34mm and some 36mm, and I wouldn't be surprised to see one with a 32mm out there.
Just clean off the sway bar with a Scotchbrite right where the bushing is so there's no dirt/grease but bar metal (without actually sanding), and use a caliper to measure.
Old Dec 22, 2010 | 03:21 PM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
Thanks! 36mm it was. Time to order some parts
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
