panhard bar ..woth replacing?
Old Dec 27, 2010 | 08:39 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi, i can get a really good deal on a panhard bar and the rear control arms..they look nice , especially in red...but is it woth changing from the stock ones?...any noticeable difference ...anyone out there changed these with some feedback..thanks.
Old Dec 27, 2010 | 09:06 PM
Stephen's Avatar
Car: 87 GTA
Re: panhard bar ..woth replacing?
Yes, especially if they have better bushings than your stock LCAs & especially if you are in to pushing your car, whether it be drag racing or autocross.
Most likely what your talking about , comes with polyurethane bushings. The stock rubber bushings are kinda weak, once you get to feel the difference you'll realize it.
Old Dec 27, 2010 | 10:32 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
I just changed my Panhard Bar and Lower Control Arms with UMI's tubulars. Really Tightened up the rear end. When you get your old panhard bar out, you'll think it's a joke. The new parts are SOOOO much stronger.
Old Dec 27, 2010 | 10:59 PM
Stephen's Avatar
Car: 87 GTA
If you replace the PHB on a lowered car, get an adjustable PHB. Even on a stock height 3rd gen, the rear axle can be offset. Mine was. I have mine within 1/8" of centered now, thanks to the adjustable PHB from UMI.
I have rod ends in all mine on my daily driver, so there is NO deflection in my bushings.
Old Dec 28, 2010 | 02:41 AM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
My bushings on my stock bar were torn when i replaced mine, plus ive seen a few bars tweaked or bent so its worth it
Old Dec 28, 2010 | 05:54 AM
mooch1's Avatar
Transmission: T5 WC
ok..thanks...i will get them ...
Old Dec 28, 2010 | 11:43 AM
ZZsmpch's Avatar
My car is at stock height, so I boxed the stock arm and added poly bushings. It made a noticable difference.
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NBrehm
Aug 5, 2015 07:57 PM
