Loud rear disc brake hum**Please read**
Old Dec 4, 2001 | 09:43 AM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
I swapped in a disc brake rearend from an 83 Z28 and I get a loud humming noise which vibrates the whole car when I apply light to medium brake pressure after the brakes heat up. Has anyone experienced this problem? Could it be caused by contaminated brake pads? I checked to make sure nothing was loose so that's not an issue. Any help is appreciated.
92' Camaro RS 305 TBI
Best 1/4 mile - 14.6 @ 96 mph w/NO NOS
Best 60' - 1.9 secs
Check it out
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=4860
Old Dec 4, 2001 | 10:07 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Might be warped rotors.
ORIGINAL OWNER
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Partial TBI mods, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Richmond 3:42 gears, Torsen HD Posi
Sights & Sounds:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers. Spectre valve covers and accessories, Z28 grille w/aftermarket lights, MacEwen whiteface gauges
NEXT UP: the rest of the TBI mods & Suspension upgrades
Old Dec 4, 2001 | 10:18 AM
pwdbychevy's Avatar
Wouldn't warped rotors create a pulsating feel rather than a humming noise though?
Best 60' - 1.9 secs
Check it out
Old Dec 4, 2001 | 10:34 AM
Pukka's Avatar
Not sure about the humming, just the vibration you mentioned.
Where did you get the rear end from?
Old Dec 4, 2001 | 12:33 PM
pwdbychevy's Avatar
I was lucky enough to work right down the road from the guys at www.thirdgenparts.com and stopped by to look at some drum brake rearends to replace the broke one I had and then low and behold there was a complete disc brake rearend hiding all the way in the back. They didn't even know it was there. I've never seen such a beautiful thing. I was happier than a pig in shiznit. Only paid $150 for it. Ok back to the vibration, it sounds like a big semi-truck coming to a stop.
Best 60' - 1.9 secs
Check it out
https://www.thirdgen.org/rides/index...ew&rideid=4860
[This message has been edited by pwdbychevy (edited December 04, 2001).]
Old Dec 4, 2001 | 12:34 PM
pwdbychevy's Avatar
ttt
Old Dec 4, 2001 | 09:01 PM
pwdbychevy's Avatar
[QUOTE]Originally posted by pwdbychevy:
[B]ttt
Old Dec 4, 2001 | 11:52 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
What kind of shape are the rotors and the brake pads?
89 T-Top GTA 350 5-speed (soon to be 6-speed)
(Jet hot coated)1 3/4 SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,ES LCA and Panhard bushings,free mods.
0-60 5.2s
Track Time
60' 2.049
E.T. 14.14@96.7MPH (2270 FT)
13.76@99.4MPH corrected
Old Dec 5, 2001 | 06:41 AM
pwdbychevy's Avatar
The rotors look fine to me. They're not warped or anything. They do need to be turned on the next brake job. The pads still look good. I'm swapping them out for carbon metallic pads to see if that fixes the problem.
Best 60' - 1.9 secs
Check it out
[This message has been edited by pwdbychevy (edited December 05, 2001).]
Old Dec 5, 2001 | 11:27 AM
Pukka's Avatar
If you pulled them out of a parts yard then there is no telling how long they have been sitting there in the heat, let alone how worn they were from the previous owner.
Warped rotors cant always be seen by the naked eye and I don't think grinding them will help either. Might be a good bet to just get new ones.
Old Dec 5, 2001 | 07:31 PM
bzznczzn's Avatar
Check the calipers, one or both can be sticking.
Old Dec 5, 2001 | 09:42 PM
pwdbychevy's Avatar
I thought it was the calipers and I did a complete rebuild on them. They are pulling back off the rotor when releasing the brakes. I finally got my parking brakes to work thanks to the tech article in this web site. My guess would be contaminated brake pads or rotors.
Best 60' - 1.9 secs
Check it out
Old Dec 6, 2001 | 04:20 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
If those are the original pads that were on there when it was laying out in the yard, replace 'em. Turn the rotors while you are at it, and that should solve your noise/vibration troubles....
Old Dec 6, 2001 | 05:17 PM
pwdbychevy's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ploegi:
If those are the original pads that were on there when it was laying out in the yard, replace 'em. Turn the rotors while you are at it, and that should solve your noise/vibration troubles....</font>
That's what I'm gonna do. Thanks.
Best 60' - 1.9 secs
Check it out
Old Dec 7, 2001 | 09:53 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Mine did the exact same thing after I had gears installed. Turned out it was contaminated brake pads. I'd replace the pads first and see if it clears it up.
1985 ASCD Ram Air Trans Am 350/5spd Pro Action heads, Comp cams XR282, Edelbrock Air Gap, if it can be changed it has Readers Ride at https://www.thirdgen.org/rides/index...ew&rideid=1067
-=ICON Motorsports=-
Old Dec 7, 2001 | 02:51 PM
pwdbychevy's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Karps TA:
</font>
Sho be nuff! That's what the problem was, contaminated brake pads. I just finished installing carbon metallic pads and drove it around and the noise stopped. Thanks guys appreciate the help.
Best 60' - 1.9 secs
Check it out
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
