What is Wheel Hop??
Old Dec 5, 2001 | 10:15 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
What is Wheel Hop??
I think my car may be suffering from this but not sure exactly what wheel hop feels like.
I own a 91' Camaro the front end is pretty tight poly bushings in place of rubber and Bilstein struts and a poly tranny mount. I have yet to do anything to the rear. Only thing not stock is the KYB shocks.
What does Wheel Hop feel like and what does it cause your car to do??
Mark
Old Dec 5, 2001 | 10:29 AM
SoCo80p's Avatar
this only really happens if you have a engine with alot of torque, when you nail the gas and spin the tires the axle will start to bounce up and down and be a big wham! wham! wham! and it feels like a eathquake inside the car.
Old Dec 5, 2001 | 11:16 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
would products designed to control wheel hop in high powered cars also benifit those that don't produce that much. I have a 91' Camaro 305 TBI
Old Dec 5, 2001 | 11:21 AM
82camaro's Avatar
Car: 82 camaro SC
It doesn't take much torque to wheel hop. Sonoma's with 2.2L 120 ft lbs of torque will wheel hop. If you can spin the tires, you have the potential to wheel hop.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Dec 5, 2001 | 09:44 PM
89Irocz23's Avatar
my will only wheel hop if i am in reverse and floored it.
Old Dec 6, 2001 | 12:18 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The best thing to prevent wheel hop on a third gen is LCA relocation brackets.
Wheel hop is when the diff rotates during accereration. Because of how the suspension is set up, after it rotates up as far as it can go, the suspension stops and gets forced back down. When this happens the movement is then transmitted to the tires and they'll be forced up off the ground. It's this rotating of the suspension that causes wheel hop.
In a leaf spring car the springs will actually bend in an S-shape. Putting on ladder bars stopped or reduced the amount of rotation which reduced or eliminated wheel hop.
In a third gen with coil springs there's no way to do this. The rotational forces push the lower control arms forward. If the front of the LCA are level or lower than the rear mounts then the forces are being pushed in the wrong way. By using LCA relocation brackets the forces are being pushed up into the weight of the car and wheel hop is reduced or eliminated.
As a side note, my car produces a lot of torque and the passenger side front LCA mount is being pushed up into the car. You can see the floorboards starting to buckle. The problem will be eliminated this winter when I switch over to ladder bars.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Dec 6, 2001 | 09:55 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Are LCA relocation brackets only designed to eliminate wheel hop or should they also be used when lowering a car? If used on a lowered car is it recommended to use them on any change in height from stock? I plan on lowering mine 1".
Mark
Old Dec 6, 2001 | 11:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Lowering a car makes the factory locations go from bad to worse. The relocation brackets help correct the bad angles.
A good set of brackets will have different holes for adjustments. You usually want the LCA's parallel to the ground but they work better when the rear is lower than the front.
Old Dec 7, 2001 | 10:56 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
can you recommend a good manufacurer for relocation brackets? I was considering Spohn
Old Dec 7, 2001 | 04:42 PM
NXS055's Avatar
ok.... this fits here i guess... Wonderbar... is that the bar that runs between the rear end and the tranny???
if so, i have one on my 92 rs... if not, then what is this bar... and is it stock
and what does it do...
Old Dec 7, 2001 | 04:50 PM
SteveSpohn's Avatar
The wonder bar braces the steering box area in the front of the car, it runs between the sway bar mounts (front).
The bar you are asking about is the torque arm.
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
Old Dec 7, 2001 | 11:59 PM
89BlackBirdKid's Avatar
I have an 89 Firebird thats only got a 2.8 and 5 speed. It had wheel hop too if it started to spin too much and now that I'm getting a 3.4 I'm worried about it even more. Are ladder bars the answer and easier way to fix this? Because I know I found some in Summit.
Any input is thanked.
Josh
1989 Firebird
Working the 2.8 to 3.4 swap with a 5 speed.
Kills: 2000 Silverado V6, 1995 v6 mustang, 1994 rodeo v6, 2001 Ford Sport trac, 1992 honda prelude riced out
Losses: 89 GTA, 95 Z28, 90 Camaro 305 TBI with mods
Old Dec 8, 2001 | 12:23 AM
AlkyIROC's Avatar
Car: 87 IROC L98
I'll never recommend ladder bars for a street car. You'll hate the ride and they're not a simple bolt-in device. Ladder bars are designed for a strip only car.
Buy some good aftermarket lower control arms and relocation brackets, panhard bar, torque arm and sub frame connectors.
There are many suppliers for each but the Spohn products are a good choice.
Old Dec 8, 2001 | 04:44 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Can a noticable difference in handling be felt after installing a wonderbar? Who is a good choice for purchasing one? I notice that Spohn does not offer these.
Mark
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
