torque arm - replacement...
Old Dec 31, 2010 | 01:39 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi, i just looked at UMI and they have a torque arm that replaces the stock one on 3rd gens,,,but what i like is that the the torque arm bolts to the transmission crossmember that they provide that replaces the stock crossmember...it actually elimintes stress on the tail end of a T5 or 700r4,,anyone out there have this on their cars?
Old Dec 31, 2010 | 01:51 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: torque arm - replacement...
I will have! I just got the T-5 relocation bracket today as a matter of fact. Should go nicely with the UMI TQ arm I already have...
Old Dec 31, 2010 | 01:54 PM
mooch1's Avatar
Transmission: T5 WC
ok,,you need the relocation bracket with an aftermarket torque arm...right?...the stock torque arm can't be bolted to this relocation bracket,,,what brand?...thanks...
Old Dec 31, 2010 | 02:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
AFAIK, the stock torque arm can but used with the relocation kits. The kit holds the factory clambshell, so i dont see what the factory arm wont continue to work.
Old Dec 31, 2010 | 02:56 PM
mooch1's Avatar
Transmission: T5 WC
what is the comapny that makes the relocation bracket?
Old Dec 31, 2010 | 03:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
UMI makes one, and i think BMR does too. Dont think Spohn does
Old Dec 31, 2010 | 05:03 PM
Confuzed1's Avatar
Car: 83Z28 HO
Like //<86TA>\\ says, You can use a factory stamped steel arm with the relocation bracket, but you need to use a 1 piece poly bushing with it.
Old Dec 31, 2010 | 05:18 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Axle/Gears: Strange S60 3.73
I have the UMI torque arm with the relocation kit on my car. I didn't keep the stock torque arm.
Old Dec 31, 2010 | 05:22 PM
Confuzed1's Avatar
Car: 83Z28 HO
That's the one I just got along with a poly bushing! Any issues with the install? I have the UMI non-adjustable TQ arm too...
Old Jan 1, 2011 | 05:47 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I got the adjustable one. I didn't come across any problems installing it. I do seem to notice a little more vibration from the car but nothing major.
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
