Front end swap
Old Dec 12, 2001 | 11:41 PM
N. Jared's Avatar
Front end swap
I bought an 89 Iroc conv. that hat been hit in the front on the driver's side. I know I will need to replace some parts. I have access to a couple firebird front ends, but I need to know if the whole subframe will swap out.
Old Dec 13, 2001 | 12:06 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The "subframe" on a third gen is part of the chassis and frame now. Unlike the second gens that could be simply unbolted and removed.
You may be refering to the crossmember. It can be unbolted from the frame and removed. Aftermarket tubular crossmembers and lower control arms are available from places like www.paracing.net
All third gen front crossmembers should be interchangable with each other. Depending on how hard the car was hit, the frame could be bent also.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Dec 13, 2001 | 09:13 AM
gravitar's Avatar
<font face="Verdana, Arial" size="2">Originally posted by N. Jared:
I bought an 89 Iroc conv. that hat been hit in the front on the driver's side. I know I will need to replace some parts. I have access to a couple firebird front ends, but I need to know if the whole subframe will swap out.</font>
Well, the thing I refer to as the subframe (maybe incorrectly) is surprisingly easy to remove. I pulled one from a junkyard car for no reason other than mine was rusty and the one at the yard wasn't
If the engine is still in the car, you'll need to support it with a bar and chain since you're removing its support structure. But once the motor mounts and tierods are disconnected, there's only something like 6 big bolts and 4 small ones holding the whole thing up! The only thing I had trouble with was the tops of the struts.. we ended up having to torch them out.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
bellez77
Sep 5, 2015 08:39 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
