Disc brake resurfacing
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
I think the inner brake pad on the LF fell off. Just reaching around the back, there's a groove in the disc brake. The disc has to be resurfaced, right? How much does this cost typically? (I want to do the pads myself, because I have lifetime warranty pads.)
Thanx guys.
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
Pioneer DEH-11
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
Thanx guys.
Pioneer DEH-11
<font face="Verdana, Arial" size="2">Originally posted by FAST RS:
Im all DAMN all in mini skirts. They had 4 sitting across 1 lying down and anothe rsitting on the girl hat was lying down. IT was Sweet when i got to practice one of my frineds was counting how many girls were comming out of my car.</font>
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
The rotor does not really have to be resurfaced, but it SHOULD be so that you can maintain even pad wear.
I don't really know what the cost of grinding rotors are, but depending on how old they are and whether or not they were turned before, you may have to buy new ones.
ORIGINAL OWNER
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Partial TBI mods, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Richmond 3:42 gears, Torsen HD Posi
Sights & Sounds:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers. Spectre valve covers and accessories, Z28 grille w/aftermarket lights, MacEwen whiteface gauges
NEXT UP: the rest of the TBI mods & Suspension upgrades
ORIGINAL OWNER
Performance:
Sights & Sounds:
Took off the brake pads today, I can't believe the lining on the inner pads were totally GONE! It was just flaking off. As for the rotor, its just the Inner Left one, and it seems as its just a deep scratch, not smooth when you go over it with your finger, as the outer part. I think what might kill me is the labor, but I could probably just take off the rotor and bring it to a shop right? How hard is it to take off a rotor?
Pioneer DEH-11
Pioneer DEH-11
Not hard at all. Loosen up the lug nutz, jack up the car, take off the wheel, take off the caliper bolts and reposition the caliper, remove the rotor.
Car: '85 IROC
What Pukka said, but to remove the rotor on the front of a 3rd gen you have to take off the grease cup, remove the cotter pin, take off the nut and pull the rotor/wheel bearing casting off. If you wanted the rotor resurfaced I think you should probably leave the bearing races in because they may be used for mounting it true in the machine. If the inner face of the rotor is just scored a little, I wouldn't even worry about it. A lot of shops will resurface rotors as a matter of course, even if they don't really need it, but that just uses them up faster.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
shotgun,
You should be able to turn slotted rotors. I have cross-drilled rotors and have had mine turned twice now. It hasn't been a problem.
Also, for anyone running Carbon Metalic pads, you should ALWAYS turn the rotors when installing new pads because the CM pads need a clean, smooth surface to seat to. It's just a good idea in general to turn the rotors each time you install new pads.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Most auto parts stores will turn them for free if you buy the pads from them. Or at the most, charge about $6 per rotor.
The nice thing is that if you ever have a problem with the "Lifetime Warranty" of the pads you bought, you'll have the proof right on the receipt that you had them turned. Most companies won't warranty the brake pads if you didn't have the rotors turned.
AJ
AJ
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Autozone has new rotors for $10 each and work great. Your rotors are probably messed up really bad if you have been driving it that way for any length of time. Not worth trying to save a couple of dollars when new rotors are so cheap.
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
<font face="Verdana, Arial" size="2">Originally posted by brharris27370:
Autozone has new rotors for $10 each and work great. Your rotors are probably messed up really bad if you have been driving it that way for any length of time. Not worth trying to save a couple of dollars when new rotors are so cheap.</font>
This new board is cool!
Dang, which autozone sells the rotors for less than the pads themselves???
Well the pads were replaced, lifetime warranty, and I didn't bother with resurfacing the rotor. Pedal feel is MUCH better now. Do you think I'll have problems in the future because I didn't resurface the rotor?
Numbah-1
Sep 12, 2015 08:57 PM
drb930
Sep 9, 2015 10:53 PM
84 TA NV
Sep 6, 2015 08:02 PM
