Use the engine for chassis bracing?
Car: 85 Trans am
Engine: 350 carbed
Axle/Gears: 9 bolt rear disk
Hi all
Ive seen race cars use this style chassis plate for mounting the rear of the engine. I was curious if this would have any effect on rigidity or if this would put to much stress on the transmission bolts. If it wouldn't damage the engine wouldn't this be a good way to eliminate the twist on the front end?
http://www.summitracing.com/parts/TCI-932500/
http://www.summitracing.com/parts/AAF-ALL38134/
Of corse it would have to be isolated somehow to keep engine vibrations out of the chassis and something similar could be done on the front if the block could handle torsional stress.
http://www.summitracing.com/parts/CEE-4004/
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Use the engine for chassis bracing?
If you start breaking motor mounts on a regular basis then you need a plate. Until then dont worry about it.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
No with a 305 I wouldn't worry about it. Put subframes on the car and call it a day. Those are more for locating the motor and not causing bore distortion under load due to high hp stresses.
Car: 85 Trans am
Engine: 350 carbed
I think you guys are misunderstanding me. im talking about using 2 flat plates to box the front and rear of the engine for stiffness and handling performance. to keep the strut towers and steering box from moving and to add more torsional rigidity. motorcycle frames use the engine as part of the rigidity of the frames.
Car: 1984 Z28
No I typed exactly what I meant, it will have little effect at your power level. Perhaps buy a strut tower brace if you want to spend some cash, the 3 point ones are nice.
Car: 1984 z28
Engine: 355
We know what your talking about.Just like it has been said you dont have the hp for that type of appilcation. If you were in the high hp and busting regular motor mounts you would move to solid mounts. Depending on your hp level even solids might start breaking and there is also alot of stress on the sides of the block where there motor mounts attached causing bore distortion and sometimes even cracking the block. Then you would move to motor plates to tie in the motor and have a better mouting point and less flex in the front end from torqueing.
Car: 1984 Z28
Solid mounts break? really....?
I've seen the sides of blocks torn off aluminum gen 3 motors and the mounts still unharmed. A motor plate is more for high HP vehicles to stop bore distortion at those levels.
Car: 1984 z28
Engine: 355
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Car: 85 Trans am
Engine: 350 carbed
What im talking about has nothing to do with the engine mounts or breaking or cylinder deformation. There is very little clearance for a carburated strut tower brace and i was thinking of useing something like a front engine plate to substitute possibly a rear one as well to lock the strut towers together
Car: 86 Trans Am
edelbrock makes a carb STB by the way. I have one on my car, slightly modified to work better IMO.
Car: 86 Trans Am
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Just a note: The Edelbrock STB won't fit a car with the AC compressor on the driver's side.
JamesC
JamesC
NBrehm
Aug 5, 2015 07:57 PM
