Camaro B4C
Old Jan 22, 2011 | 08:12 AM
91ILLWILL's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: 5 Speed
Axle/Gears: 3.08?
Camaro B4C
Ive got a 91 RS. Ive tried to post pics of it but alas....no success. I dont know why but I think Ive tried everything. Anyway, 91 RS 305 TBI 5-speed tranny. Not the fastest, but it starts everytime, and runs great considering it has 199xxx miles. The entire car is stock (with the exception of the cd player that I put into it, oil, filters, wires, plugs, yada yada). I know anyone who truly values their 3rd Gen can appreciate that. I think that the B4C Camaro is an RS body with Z28 suspension and motor? I want to keep the RS because its unmolested and pretty clean for its history.
Would it be worth it to try and basically build a B4C clone? I dont know how much (if any) the suspension would need to be beefed. A 350 TPI would be nice but i have TBI would that work? What would I need to make my RS a B4C Clone?
Old Jan 22, 2011 | 08:22 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Camaro B4C
Put a Police decal on the door and you will have B4C clone.
Old Jan 22, 2011 | 08:40 AM
91ILLWILL's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08?
Re: Camaro B4C
Funny. No thanks.
Old Jan 22, 2011 | 09:32 AM
DJP87Z28's Avatar
Re: Camaro B4C
Originally Posted by 91ILLWILL
Funny. No thanks.
RPO B4C is for a "public service vehicle" aka "police car" .So no mater what you are trying to clone at this late date, it still will NOT be a B4C car. It will just be a modded RS. My opinion the decal is a better idea.
Old Jan 22, 2011 | 09:48 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Camaro B4C
what do you consider "worth it", the car may be worth a little more since you would be installing a more desirable engine, but the cost involved would negate any gain when it came time to sell.
if you want the better engine, go for it, but do not consider it an investment that you will make a profit on.
Old Jan 22, 2011 | 11:44 AM
Re: Camaro B4C
B4Cs all got TPI and the 1LE brake system, and minor transmission mods.
Other than that, they're not anything special.
But as said, either it IS a B4C, or it's NOT a B4C. If you're is NOT a B4C, then .... you do the math.
However, that's not the same as saying you couldn't put all the things that a B4C would have on it; but that won't make it a B4C. It will absolutely NOT affect the "value" one way or the other to any significant degree. An actual B4C has some certain value from BEING a B4C; a car that isn't a B4C, doesn't have that value, no matter what mods are done to it. The "value" of the car stands on its own, not on what it's a partial clone of.
Old Jan 22, 2011 | 03:44 PM
91ILLWILL's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08?
Re: Camaro B4C
"Worth it" to me is putting money, work and time into an RS to make it a beefy RS (B4C clone). Or spending money on an IROC. I could have new performance or original rareness. I like the RS because its clean and all original, although I like the rareness of a 91 IROC. I dont just want to throw parts at it and call it good. I want it to actually be something. In this case, the word "clone" relates to performance. Not a cop car with lights, sirens, and decals. I want it to relate to something original, in this case a B4C (performance) "clone". From what I understand, they were made in 91 with an RS body, performance suspension and a bigger engine. And I understand that if its not an original B4C, Than its not an original B4C. Hence the term "clone".
Old Jan 22, 2011 | 07:50 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Re: Camaro B4C
A b4c clone would doubtly be recognizable as a clone. If that were the case plenty of people have rs cars wth tpi engine but yet they don't consider it a b4c clone. A B4C car is far from a performance car, not all had 1le brakes. I'd say upgrade your car in whichever way suits you and don't worry about trying to copy a b4c
Old Jan 24, 2011 | 04:16 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Camaro B4C
A clone is still just a clone. Money spent and no increase in value.
Just modify your RS the way you want it.
Old Jan 27, 2011 | 11:38 AM
KMK454's Avatar
Car: 1991 Camaro B4C
Re: Camaro B4C
I have a 91 B4C (non-1LE) 305TPI/T-5.
For purposes of the VIN/titling/insuring, it shows up as a Z28 Coupe, and all the common Z28 RPOs are there (LB9, FE2, etc.).
The first run of 1991 B4C cars did not have 1LE; the second half did. In 1992, all B4C had 1LE. The primary difference is the front brakes. My car is basically a 1991 Z28 with radio delete; the B4C RPO code gives me RS bodywork instead of the Z28.
Old Jan 27, 2011 | 09:51 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Re: Camaro B4C
i have a 92 B4C 1LE... only thing cool about it is that it got the 36/24mm sway bars, 1LE brakes/rear disks, 3:42's and a TPI engine. My car was actually an LB9 5 speed.. they didnt get any special springs... but did have the harder durometer bushings that 1LE cars had.
think of it as a Z28 with an upgraded brake package. My car also has manual doors/windows.
Old Feb 8, 2011 | 01:17 PM
OhioB4C's Avatar
Car: 91 B4C,1979,1968 Camaro
Re: Camaro B4C
Not all 1991 B4C Camaros are "aka police cars", i own a B4C 350 or 5.7 TPI 1LE That is Bright Red with Radio and light brown leather seats Power everything and cruise this is all Factory. i still have the window sticker for this car.
Old Feb 10, 2011 | 01:03 PM
KMK454's Avatar
Re: Camaro B4C
Yup; they weren't supposed to get sold to the public but sometimes did, either because of dealer error or a cancelled order from the government that left a B4C on a Chevy lot. Also, some insiders knew they were getting something different and worked the system...
Old Feb 17, 2011 | 09:18 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
Re: Camaro B4C
THERE NEVER WAS AND WILL NEVER BE A 1991 IROC
https://www.thirdgen.org/1991-chevy-camaro
Old Feb 17, 2011 | 09:21 PM
regal301's Avatar
Car: 1988 iroc-z
Re: Camaro B4C
B4C = Z28 WITH RS BADGES..............
Old Feb 17, 2011 | 09:33 PM
regal301's Avatar
Car: 1988 iroc-z
Re: Camaro B4C
not all had 1LE
try the search tab up top
B4C `Special Service' police package became available to law enforcement agencies only. Cars were RS coupes with Z28 5.0 TPI or 5.7 TPI drivetrains and Z28 suspensions. These cars came equipped with the 16 inch wheels and P245/50-ZR16 tires, engine oil cooler, rear disc brakes, and limited slip axle. >>>Midyear, the 1LE 11.86 inch front brakes and HD calipers became optional for the B4C.<<<< This package was the only way to get air conditioning and the HD front brakes. There were 592 1991 B4C Camaros built.
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
zerogsx
Feb 6, 2016 11:29 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
