Shaft between steering column and steering box?
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
What is the tech name of it? I need a replacement and could not find one on Autozones site. Are these still available or is a yard replacement the way to go?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Shaft between steering column and steering box?
Lower steering shaft
I doubt you'll find a new replacement but you never know. A junkyard replacement is more likely.
Why does it need replacing? The shaft itself shouldn't wear out. The rag joint could be easily replaced.
If you do a search, you can find a thread on using the lower steering shaft from an Astro van that should be an almost direct swap plus gives you real u-joints.
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Another name is Intermediate Shaft. I found a New one on Ebay, but it was EXPENSIVE. I think i paid over $100 for it. I should have just replaced the Rag Joint, but I didn't know any better.
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
yup, that's it
Car: 1987 IROC - Z
Engine: 5.0 TPI
auto zone calls it a steering coupling, but you will need (4) 5/16-24 lock nuts and (4) 5/16-24 1 1/2 bolts
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
